Polk Audio
Old Jan 22, 2002 | 04:37 PM
salsaweb's Avatar
I went out to a CarAudio store and listened to various brands of 6 1/2 speakers to replace my current '01 stock speakers.
Of the 5 or 6 different brand names:
The best sound, and this is only my personal opinion, was produced by the Polk EX-365's
I visited www.PolkAudio.com and found that there is another, yet higher model.
The dX6 costs more but has only 40w or continuous power vs 60w of the EX series.
Peak is also lower at 130w vs 180w.
Being a Audio novice I don't know the PRO's and CON's of the specs.
Please help me choose the speakers that would BEST fit the stock '01 head unit.
Will I have to CUT much to fit the speakers?
Install dimensions are:..............EX365........................... .........dX6
Driver Mounting Depth
Top mount..............................2-1/16" (5.24cm)....................2-9/16" (6.51cm)
Bottom mount.........................2-5/16" (5.87cm)....................3-1/8" (7.94cm)
Grille
Height.....................................9/16" (1.43cm).......................1-1/8" (2.86cm)
Diameter.................................6-1/2" (16.51cm)....................7-3/8" (18.73cm)
Driver Cut Out Diameter..........5-1/4" (13.34cm)....................5-1563/10000" (13.10cm)
Also would like to know if I need to purchase additional hardware to install these.
My plans are to keep the stock unit and only change the door panel speakers.
I don't want to add amps or extra tweeters/bass, etc.
I checked prices and I can get either set for about the same.
Please help.
Old Jan 22, 2002 | 04:42 PM
salsaweb's Avatar
EX365
dX6
Old Jan 22, 2002 | 04:58 PM
Utah S2K's Avatar
What are the tech spec for the speaks not just dimensions.....i.e. sensitivity and wattage?
Stock head unit sucks and may not drive these?
Old Jan 22, 2002 | 05:23 PM
salsaweb's Avatar
Thanks UtahS2k
Old Jan 22, 2002 | 05:53 PM
salsaweb's Avatar
-------POLK EX365---------------------------------------------------------
Driver Complement
Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
Tweeter 1 - 3/4" Diameter (1.91cm)
Soft Dome Tweeter
Electrical
Overall Frequency Response 55-22kHz
Nominal Impedance 4 ohms
Power Handling (continuous) 60 w
Power Handling (peak) 180 w
Efficiency 92 dB
-----------POLK dX6---------------------------------------------------------
Driver Complement
Polymer Composite Cone
Tweeter 1 - 1" Diameter (2.54cm)
soft dome
Electrical
Overall Frequency Response 50hz-20khz
Power Handling (continuous) 40 w
Power Handling (peak) 130 w
Efficiency 90 dB
Magnet Weight 10.00 oz.
Old Jan 23, 2002 | 12:25 AM
kumar75150's Avatar
I got the Polk EX602a and the guy at the audio store said they were the best ones they carried and I am happy with the sound.
Old Jan 23, 2002 | 01:14 AM
salsaweb's Avatar
kumar75150
Did you need any special plug or adapter?
Did they fit in perfectly or did you have to cut to make space.?
Old Jan 23, 2002 | 02:25 AM
lucid's Avatar
Did they fit in perfectly or did you have to cut to make space.? [/B]
The 602a and the 365 will drop in fit the basket. The only adapter needed is the speaker to OEM harness which is the same used on all hondas. I carry the polk line.
Old Jan 23, 2002 | 08:04 AM
jps2k's Avatar
i have the dx-6. they are powered by a small mtx thunder 152 that was installed in the tool tray. i'm not an audiophile but when comparing them with infinity kappas they seemed to have a bit more bass. if i remember correctly i purchased them on e-bay for $110. i also had to cut the speaker baskets and use the adapters described by lucid.
Old Jan 30, 2002 | 03:10 AM
salsaweb's Avatar
jps2k you have PM
Mish
Jun 9, 2015 10:56 PM
Emil St-Hilaire
Oct 20, 2005 06:21 AM
jal3lee
Aug 4, 2005 12:34 PM
puffman20
Jun 23, 2004 01:44 PM
KDuke
Jul 6, 2001 10:40 AM
