Possible fix for for the auto-rolldown problem
Old Apr 13, 2008 | 07:49 PM
  #131
NoRawkus305's Avatar
Can someone elaborate what this auto-rolldown problem is? A little confused and curious if I have this problem, too. TIA.
Old Apr 13, 2008 | 08:09 PM
  #132
Adeeos's Avatar
Ok guys,,, My 00 started not working about month after I bought it,, (used with 110,xxx,,, now has 118,xxx),,, Saw the TSB about it and it mentioned, "corrosion in the window motor" as the fault,, I didn't pursue fixing it since it still worked fine when holding the button down,,, Anyway, I saw this thread,, and somewhere in it,, saw someone mention that it may be corrosion on the contacts,, which could be, "removed" with some constant use,,, Sooo, here's what I just did,,, went out to the garage,, ran the window fully down, then fully up, several times by holding the switch in both directions of course,,, I did it with the motor off,,, Then started the motor to have full voltage from the battery,,, again, ran it up, down, up, down several times,,, the auto down function NOW works,, !!!!,,, Then noticed that it was sorta, "shuttering" a couple of times in the middle of it's travel down... So,, popped the door panel off,, ran the window all the way up,, then reached inside the access hole in the bottom left,, and sprayed some white lithium grease all up and down inside the vertical track,, Put it all back together,, and it now works PERFECTLY!!!,,, Hopefully the age of the car, caused the drying of the lube in the track,, and was causing the switch to trip out,, Just thought I'd let you guys know to try it,,,,
Old Apr 13, 2008 | 11:44 PM
  #133
raisantos's Avatar
Old Apr 13, 2008 | 11:51 PM
  #134
qbmurderer13's Avatar
x2
Old Apr 14, 2008 | 07:30 AM
  #135
chickdr's Avatar
It is the one touch down feature of the driver side window. Some have trouble with it working from time to time.
Old Apr 19, 2009 | 08:34 AM
  #136
Jamie6's Avatar
Thanks to JSfetko for the post and to XaznX for the fix, it worked perfectly for me too!
Old Apr 19, 2009 | 06:38 PM
  #137
starchland's Avatar
i did the fix worked fine for the day (auto down - seems like the memory forgets to add the little click when the button is fully pressed down) but it seems sometimes it still does it occasionally.
Old Jun 20, 2009 | 09:25 PM
  #138
Groove_D's Avatar
You guys are confusing the regulator and the power window motor. Power window motor is responsible for the auto feature of the window, not the regulator.
Old Sep 3, 2009 | 07:52 AM
  #139
dammitjim's Avatar
I just got my 02 and the auto-down never worked and the driver's window would only go down 1/2 way when the top was lowered. I did this fix and both functions now work perfectly. Thanks OP!
Old Oct 12, 2009 | 08:40 PM
  #140
AMBAICAR's Avatar
wow cool
Goldtrom
Feb 27, 2003 07:40 AM
mas
Jan 14, 2003 04:06 PM
Squeezer
Mar 21, 2001 06:03 PM
PokS2k
Nov 20, 2000 04:25 PM
