Possible fix for for the auto-rolldown problem
Old Sep 2, 2003 | 05:24 AM
  #111
lanbrown's Avatar
[QUOTE]Originally posted by Dallas
[B]
Are you sure about that?
Old Sep 2, 2003 | 05:15 PM
  #112
Dallas's Avatar
Originally posted by lanbrown
The front will fit the rear but the rear will not fit the front.
Do a search and you will see that a few people had the rim incorrectly installed on the car and the front will develop a vibration because the rear rim will not seat correctly on the front.
I understand. Thanks.
Old Sep 2, 2003 | 05:24 PM
  #113
Sharp Chuter's Avatar
Huh... I thought you weren't supposed to use the spare tire on the rear of the car because we have a limited slip differential and the spare is smaller in diameter than the rear tire, meaning the LSD will be slipping all the time and will overheat / burn up / be damaged. The front tire is the same diameter as the rear, so it won't hurt the LSD. The spare can be used on the front because there's no differential up there.
Old Sep 2, 2003 | 08:39 PM
  #114
Chitah831's Avatar
[QUOTE]Originally posted by Sharp Chuter
[B]Huh...
Old Sep 3, 2003 | 05:36 PM
  #115
RacingRod's Avatar
Hey; it just worked for me.. great! Thanks
Old Sep 6, 2003 | 09:12 PM
  #116
jsc2K's Avatar
I think it also worked for me too! it was getting kind of annoying...but the funny thing is that I didn't really know about the auto-roll down problem until reading this thread...then after reading about the problem, my auto-roll started to malfunction which wasn't happening before...I hope this doesn't start a trend hahah. Thanks guys for the fix for now hahah
Jason
Old Sep 15, 2003 | 08:56 AM
  #117
rickycrx's Avatar
Just had mine replaced about a month or so ago for the second time... Now the problem seems to be gone for good.
Old Sep 17, 2003 | 11:47 PM
  #118
jsc2K's Avatar
it worked for a little bit..and now is back and annoying me. Probably going to get the dealer to fix it when I have the time...
Old Nov 10, 2004 | 05:34 PM
  #119
PJK3's Avatar
had the new part put in quite a while ago (probably on the order of a year ago, when this thread was relatively fresh).
the new part started to fail last week. it has become a constant regular failure, and far more consistent than the original.
need to pull my paperwork and see if i can track down the receipt. i'm going to see if i can get it covered under replacement warranty.
Old Nov 11, 2004 | 03:43 AM
  #120
Rickjames's Avatar
I need to try this--I hope it works
