Post Lowering
Old May 14, 2004 | 12:44 PM
oneboy2c's Avatar
Default Post Lowering
I am going to lower my car this week with eibachs. I am just wondering what i need to do on my car after the springs are installed. Does it need a alignment? Anyhting else? Thank in advance for all your help.
Old May 14, 2004 | 12:56 PM
EssTooKayTD's Avatar
I think you just need to let the springs settle, that's about it. I'm not an expert though
Old May 14, 2004 | 01:05 PM
cornercompacts's Avatar
if you have a shop do it they will make sure the car is aligned and the camber is correct before you leave with it, that is if they know what they are doing
Old May 14, 2004 | 02:43 PM
wanabe's Avatar
and a third opinion...
i think you should drive the car for about a week to let the springs and suspension settle then get it aligned.
spugen just installed mine last week and i have an appointment with darin (west end) for a full alignment in about a week.
eibachs on this car:
Old May 14, 2004 | 02:44 PM
jchung's Avatar
nice drop
yes make sure they align it and adjust your cambers.
Old May 14, 2004 | 02:59 PM
chrissa's Avatar
More importantly, you need the toe corrected when the alignment is done.
Old May 14, 2004 | 04:29 PM
hyperpm's Avatar
Let springs settle for a few days then get an alignment.
Old May 14, 2004 | 04:39 PM
s2ka's Avatar
Eibach smacks each springs with something like 40 tons of pressure on a gigantic press to solve the settling problem. Mine haven't moved at all, the height measurement is exactly what it was the first day I put them on. If you have a chance to take the Eibach factory tour you will see that step.
That being said, have a good alignment shop give you a 4 wheel alignment. You can search the forum for recommendations on what specs to choose, I went for right in the middle of Honda's minimum and maximum specs. Perfect tire wear so far, even on the racetrack.
Lookin' good wanabe.
Danwolski
Sep 30, 2012 05:55 PM
gios2k
Mar 29, 2012 04:38 AM
Broken2G
Apr 13, 2008 09:56 PM
CyBerNeo
May 24, 2005 02:50 PM
Mok
Mar 13, 2004 11:26 AM
