power loss
Old Dec 8, 2001 | 09:04 AM
sweetj's Avatar
Default power loss
Has anyone had problems with the power cutting out when you get in the 6000rpm range? It's like the same feel as hitting the rev limiter.
Thanks
Old Dec 8, 2001 | 09:12 AM
kidwhiz's Avatar
I have, twice. It felt like it dropped out of gear for a bit. I have a 2002, and it happened at around 1K miles and 1.2K miles in 1st and 2nd. Both times were less than 5 minutes after I cold started the car. I don't vtec until the engine's warm now...
Old Dec 8, 2001 | 09:15 AM
sweetj's Avatar
This has been happening after the car is warm. It happens from 3rd to 4th and higher gears. I'm wondering if there is something wrong with the vtec.
Old Dec 8, 2001 | 09:22 AM
mingster's Avatar
your engine is not warm.
Old Dec 8, 2001 | 09:25 AM
sweetj's Avatar
This happens after I've been driving for at least a half hour. The engine is definitely warm by then.
Old Dec 8, 2001 | 09:34 AM
kidwhiz's Avatar
it's got to be a car problem, then. search the forums for a trusted mechanic. hopefully you'll find one near you.
Old Dec 8, 2001 | 09:48 AM
2fast4u's Avatar
hey make sure that your oil level is ok if your oil is to low it will turn off vetec
make sure it is not to full our to less
Old Dec 8, 2001 | 09:52 AM
sweetj's Avatar
Just replaced the oil not too long ago but I will check it out. Thanks
Old Dec 8, 2001 | 10:01 AM
cdelena's Avatar
It sounds like it may be the MAP sensor. Do a search and you will find dozens of threads dealing with the problem.
tommygun124
Mar 1, 2009 02:34 AM
dean29
Sep 26, 2008 04:04 PM
neko_cat
Nov 6, 2003 07:18 AM
Wisconsin S2k
Apr 30, 2002 10:56 AM
