Pressing the "Start Engine" button twice
Old May 12, 2006 | 01:14 PM
Ks320's Avatar
Default Pressing the "Start Engine" button twice
Just curious: Did anyone accidently press the start button while the engine's already running?
Does the starter grind? Or is it smart enough to ignore the input?
Old May 12, 2006 | 01:15 PM
GPW03's Avatar
Good question. I've always wondered this, but never dared to try.
Old May 12, 2006 | 01:17 PM
nightcrawler7188's Avatar
before i had my Invidia (when the engine was quiet at idle) i pressed the start button while the engine was already started, and it did grind.
Old May 12, 2006 | 01:21 PM
Tolgahan Ures's Avatar
i am also curious about that too. a parking valet did that to my car.
dmz's Avatar
dmz
It will grind if you keep the clutch pedal depressed.
Old May 12, 2006 | 02:23 PM
meth's Avatar
i pressed it once before, it grinded, i don't remember if i was on the clutch or not. in other words, don't press it.
Old May 12, 2006 | 02:28 PM
Ks320's Avatar
Dang ... I was hoping that the starter is smart enough not to grind ...
Old May 12, 2006 | 02:36 PM
JEFFOS69's Avatar
As long as you arent holding down the clutch (why you would be depressing the clutch and pressing the button after its started I do not know) it will not grind. - press it all you want.
Old May 12, 2006 | 03:48 PM
FLsanshou's Avatar
I did this before by accident when I first got my car
If the clutch isn't being pressed nothing happens but if the clutch is pressed it will grind just like if you were to turn the key on a car that was already started
Old May 12, 2006 | 03:55 PM
r_duff's Avatar
its just a button. there are no microchips, relay, electronics at all. Its the equavalent of turning your key to touch 2 contacts in a non-'start button' car.
