PROBLEM STILL NOT SOLVING by DEALER
To professional guys:
When I drive over the Bump I can hear "Clo Clo" sound from passenger front underneath. But Service technicians are not solve it out. I have been there for this problem almost 6 times...
Problem: drive slowly passing the bump and sound will go "Clo Clo" under passenger side.
Technicians work: Put oil in the rear and front sway bar. tight all the suspension front and rear.
Technician comments: cannot hear the sound after work
P.S. sometimes you can hear but sometimes you won't hear..
If you go over the right bump then you will hear that.......
*** BUT I CAN STILL HEAR THE SOUND when I pass the bump or drive slowly(20km) in the very Rough road.
Sad driver
Sad driver
The sound is coming from Passenger front bottom...
Actually dealer thought is suspension problem..They try to put some lubricate on the sway bar front and rear . Also tight the suspension up....
But still
But still
Are you braking when this happens? The reason I ask is when I was first driving my Civic Si (first car I had with ABS) if I went over bumps while slightly compressing the brake pedal, the ABS would chatter away. The first time I heard it it freaked me out until I discovered what it was. Granted I haven't driven my S yet so I don't know whether this happens to all ABS cars, but it sounds like what you're describing. Hope this helps. Cheers.
[QUOTE]Originally posted by S-ToDo
[B]To professional guys:
