programming key fob help
Old Sep 20, 2012 | 09:21 AM
lopez14's Avatar
Default programming key fob help
Hey guys so I've never had a key fob on my s since I've had it, and I ordered a used oem one on eBay and I just got it and tried programming it but no luck, I tried the instructions I've found on here by searching but it doesn't work I have a MY00 can someone post instruction for me that are verified to work? Also did I even order the correct remote? Fcc id-A269ZUA101 REF NO. HFR-610 serial number w8701327356a thanks!
Old Sep 21, 2012 | 06:26 PM
AZS2KDancer's Avatar
I bought a second remote fob, as I only had one when I bought my S. I followed the seller's instructions, but couldn't get both my new fob and the old one to work at the same time. I ended up calling their tech help line and we walked through the process a dozen times.
Try the programming with the driver's door open and closed to see if that makes a difference. It did for mine. when we got done with a successful job, I recommended a re-wording of their instructions to make it clearer. I believe you have to follow the repeat key on, hit button and repeat, procedure for a total of four (4) times.
Old Sep 22, 2012 | 07:36 AM
lopez14's Avatar
Thanks for the help but here's my follow up https://www.s2ki.com/s2000/topic/980...#entry22030157
aznsupastar
Jan 31, 2020 12:19 PM
lopez14
Sep 20, 2012 10:10 AM
iceman86
Apr 21, 2010 10:10 AM
daveeppy
May 30, 2008 08:52 AM
ED1
Dec 23, 2005 02:35 PM
