proper downshifting technique?
Old Feb 21, 2005 | 09:43 AM
eepr5's Avatar
Default proper downshifting technique?
Ok, this is sort of a two part question thats been bugging me for a while. After seeing a recent post about damaging a part in the transmission from shifting from 6th to 4th and skipping 5th completely, I thought I'd ask.
btw, I fully understand and practice the concepts of heel/toe and rev-matching, thats not what this is about.
First, when the need arises to downshift by several gears, like being in 5th and dropping to 2nd or 3rd for a corner, is it OK to just go from 5th to the desired gear, skipping 4th, etc in the process, or should you incrementally downshift 5-4-3-2?
Second, should I engage the clutch in every gear as I downshift, or keep it pressed the whole time?
example
in 5th
press clutch
shift to 4th, match revs
release clutch
press clutch
shift to 3rd, match revs
release clutch
continue driving
in 5th
press clutch
shift to 4th
shift to 3rd
match revs
release clutch
drive
Old Feb 21, 2005 | 10:21 AM
hpark's Avatar
i don't think you need to go through every gear....
okay to to go 5th to 3rd, just blip throttle to rev match as usual...
i'm sure someone on here will tell me im wrong if i am
Old Feb 21, 2005 | 10:53 AM
Mandocorri's Avatar
No problem skipping gears, just make sure that you are in the right speed range so that the lower gear doesn't go ballistic, unless I guess you want to use it to slow down in an emergency. You also have to be careful of course to hit the right gear. If you mean to go from 6th th 4th, don't accidentally put it in 2nd. Ciao, Tonino.
Old Feb 21, 2005 | 11:26 AM
steven975's Avatar
in 5th
clutch in
shift neutral
clutch out
rev-match
clutch in
select gear
clutch out.
if you rev match WHILE you are pressing the clutch, you are not matching the flywheel and input shaft at all.
Old Feb 21, 2005 | 11:36 AM
CaptKirk's Avatar
Originally Posted by steven975' date='Feb 21 2005, 03:26 PM
in 5th
clutch in
shift neutral
clutch out
rev-match
clutch in
select gear
clutch out.
Please correct me If I'm wrong, but shouldn't synchros on our trannsmissions take care of the matching of revs on the input shaft? I thought this technique (which is double clutching from what i think, once again correct me if im wrong) was rendered unnecessary due to the synchros?
Old Feb 21, 2005 | 12:16 PM
Warren J. Dew's Avatar
You can skip gears. Just make sure:
1. When skipping gears, give the synchros plenty of time to do their job - don't speed shift.
2. Match revs for the gear you are going to. Don't downshift to a gear that will put your engine above redline, even accidentally. Going to too low a gear and overrevving is the main cause of blown engines in the S2000.
Old Feb 21, 2005 | 12:24 PM
jlstyle82's Avatar
hmmm ..another dumb question.
i thought if you press the clutch, its in same situation as you put gear in neutral?
guess not? cuz i just to rev match while pressing down the clutch.
lead me to right direction masters~
Old Feb 21, 2005 | 12:29 PM
SIIK2NR's Avatar
Originally Posted by steven975' date='Feb 21 2005, 12:26 PM
in 5th
clutch in
shift neutral
clutch out
rev-match
clutch in
select gear
clutch out.
1. You don't need to downshift through all the gears. Just make sure that you are braking enough that your overall speed is with in the limitations of the gear you end up selecting. ie 2nd gear. Definately rev-match.
2. Double clutching is not required
3. Engaging the clutch and then systematically shifting downshifting through the gears is pointless if your not releasing the clutch.
Old Feb 21, 2005 | 12:30 PM
mikegarrison's Avatar
clutch disengaged (pedal pressed in) = transmission input shaft disconnected from engine
neutral = transmission output shaft disconnected from transmission input shaft
Old Feb 21, 2005 | 01:29 PM
Chazmo's Avatar
in 5th
clutch in
shift neutral
clutch out
rev-match
clutch in
select gear
clutch out.
Yes, I think this is correct. Steven is talking about double-clutching.
If you're skipping multiple gears, I think I would recommend this technique.
