Proper Replacement Key
Old Dec 17, 2018 | 08:28 AM
Say Chi Sin Lo's Avatar
Originally Posted by Deckoz
All s2000 are immbilizer chipped. Honda dealership should only charge you the cost of the key($45). They put your key in a machine which powers the chip so the code can be copied to the new cut key
Great!
Thank you.
While I'm at it, I need to do the same thing with my Mazdaspeed too...
Old Dec 21, 2018 | 01:52 PM
Bjehle's Avatar
Default genuine master key and xmitter
I know it's expensive but I have to have Genuine, here's what works:
genuine master key that needs to be (can be) cut and "cloned" by dealer
genuine xmitter for non alarmed cars with trunk button
Old Dec 21, 2018 | 01:57 PM
summitrider2012's Avatar
I work at a Honda dealer and the key cutter we have can not do that. We have to use the HDS to program the key and it’s usually around 50-60 I believe.
Old Dec 21, 2018 | 02:30 PM
Kyle's Avatar
Or.... This!
Old Dec 21, 2018 | 03:48 PM
Bjehle's Avatar
that was my experience too, the dealer Keyes (ironically) in Van Nuys/Woodland Hills doesn't have the right machine in parts to do it so you have to go to service for a tech to do it.
Old Dec 21, 2018 | 03:59 PM
Hfreak's Avatar
I have had a couple new keys programmed for two '06+ cars and they need the car to do this, was only $30 each time so no complaints here.
Old Dec 21, 2018 | 04:38 PM
Deckoz's Avatar
obviously every dealership is different. But my local dealership did it all without the car.... sooo
Old Dec 23, 2018 | 02:23 PM
Hfreak's Avatar
I think the immobilizer system in the 2006+ is slightly different than the 1999-2005, I believe that a key can be cloned in the earlier cars but not the 2006+. Someone please correct me if I am wrong.
Old Apr 24, 2020 | 09:20 AM
Luxs2k's Avatar
Bringing back this thread as it would be great to fully confirm this information.
Key 35113-S84-A02 - Does this key need to be cloned from an existing key (i.e. it is writable) or does it need to be added to the ECU (has it's own unique code)? I recently tried to have this key added to my ECU (MY 2001) and the dealer equipment was not able to recognize the key.
Key 35113-S2A-000 - This sliver head key has no immobilizer chip inside it. Correct?
Old Apr 24, 2020 | 09:46 AM
Unbeliever's Avatar
That doesn't look like an S2000 key (at least a US 2006 key). The US key doesn't have ward channels on it. It's just a flat plate with the key pattern raised on each side.
Edit: Yup. That's a JDM key, not a US key.
This is a US Market key blank:
