Proper Replacement Key
@JimSt The E-Bay key that I linked is specific for the AP1, not AP2. If you buy an AP2 immobilizer blank and get it cut at a locksmith, you can still use the Autel AP200 to program your blank to the ECM.
eBay seller lists key as 2004 compatible so I assumed their photo was wrong. I have contacted them. Will see if they update the listing.
(anyone want a deal on a pair of AP1 keys?)
Will the Autel AP200 work w/ genuine Honda oem blank keys?
I bought a genuine oem blank (red H) for my Ap1 in 2014... procrastinated getting it cut & programmed ever since tho.
I assume the genuine oem A01 isn't "Writable"/clone'able like those eBay ones, and it's the other way around - need to program ecu, or add new key to ecu? (as it has its' own unique code, un-writable/clone'able?)
Edit:
Just checked bag/key... my key is exact same as this one...
35113-S84-A01
https://www.s2ki.com/forums/s2000-ta.../#post24909915
Edit:
35113-S84-A01
@Jah2000 There are two types of blank immobilizer keys - (1) writable/clone-able/programmable where the transponder of an existing working key is cloned to the new blank and the ECM doesn't know the difference, and (2) fixed transponder where the ECM must be programmed to accept the transponder signal from the new blank. All OEM keys are fixed transponder and the programming service is handled by the dealer OR you can DIY it via the Autel AP200 OR the CK-100. Yes, the Autel AP200 will work with genuine Honda OEM blanks.
I have ordered this blank : 35113-S9A-A01
https://www.hondapartsnow.com/genuin...3-s9a-a01.html
Which is said to be suitable for my 2004.
Am I correct in thinking that with the Autel :
1. I should follow the instructions on page 4 of the TSB mentioned above - with the Autel taking the place of the HDS?
2. Adding a single key will not affect my 3 original keys?
TIA, Jim
TIA, Jim
With the Autel AP200, you can:
Delete all previously programmed keys and start a new library.
or you can just add a key to your existing library.
And then enjoy an awesome Honda specific diagnostic tool thereafter.
I've only found out about this cheaper AP200 from these very recent posts... before, the only one I've read of was the expensive CK-100; which some members offer renting out (I'd never buy one myself).
A few years ago, I was planning to just have a 3rd-party/Yelp car-locksmith cut & program my key/ecm... but they all charge around $90-110.
Seeing that the AP200 is much cheaper than a one-time locksmith service, I will just get the AP200... bonus, I can use it to check for any future engine-codes/check-engine lights!
Where in California are you? If you're in the Bay Area, you could come by and I can program the keys for you. Of course, the vehicle must be registered to you and you'd have to show your ID before I'd do it.
https://www.bestbuy.com/site/autel-a...app/6538716.p?
