Putting an AP2 engine into an AP1?
Old Nov 23, 2006 | 09:09 AM
FormerH22a4's Avatar
Default Putting an AP2 engine into an AP1?
Has anyone put an F22C into an AP1 yet?
If so, what is all needed?
Just thinking later down the road if I need an engine replacement?
Thanks.
Old Nov 23, 2006 | 09:28 AM
Woodson's Avatar
You should easily get more than 200,000 km's out of your engine. Your car will be 10 years old by then.
Old Nov 23, 2006 | 09:57 AM
Hopefully I can make it to 200,000kms
The new bottom end of the engine was replaced at 90,000kms. Perhaps I can get to 300,000kms with this engine.
Old Nov 23, 2006 | 10:54 AM
Ks320's Avatar
I think someone from the New York Metro area has done it ... can't remember who though ...
Old Nov 23, 2006 | 12:00 PM
Stratocaster's Avatar
I know of several F22 installed in AP1 cars. The swap is straight forward. The head and block are exactly the samw from an installation standpoint. The only real differance is the ECU. Some have run it with the Ap1 ECU and many others with the AP2 ECU. Either will work, but I think the AP2 ECU is more common from the swappers. The wiring and ECU are straight swaps. You would need to swap the speedo and harness to get that to work in an AP1, but It would not be required.
Old Nov 23, 2006 | 04:31 PM
gomarlins3's Avatar
What would be the upside to making the swap? Just wondering.
Old Nov 23, 2006 | 05:42 PM
Chris S's Avatar
Defender has done it - he was living in NY, but now divides his time between there, Georgetown, TX, and Mexico.
Old Nov 23, 2006 | 05:45 PM
Steve@Evolution's Avatar
I have done one and I used AP1 ecu. Everything is all plug and play. Just remember to swap the drive shaft end on from the AP1 transmission to the new Ap2.
If I remember correctly, the reason I didn't use the AP2 ecu was because the immobilizer I think..
Steve - Evolution
703-961-9090
Old Jul 10, 2008 | 10:30 PM
speedstar808's Avatar
Steve - Evolution
703-961-9090
Steve,
I only have an AP1 drive shaft but planning on swapping in an F22 w/tranny. will the swap fit or do I need AP2 drive shaft, then swap the ends??
thx
Old Aug 11, 2009 | 11:18 PM
pridyuk's Avatar
hey guys , when you drop ap2 2.2l engine into ap1 chasis, will you still pass smog? and which injectors you use? ap1 or 2?
