Putting an AP2 engine into an AP1?
Old Aug 12, 2009 | 01:30 AM
Snowmoto125's Avatar
Originally Posted by pridyuk,Aug 12 2009, 12:18 AM
hey guys , when you drop ap2 2.2l engine into ap1 chasis, will you still pass smog? and which injectors you use? ap1 or 2?
Back from the dead! I don't see why you wouldn't pass smog?
Old Aug 12, 2009 | 07:14 AM
JP Money's Avatar
Shouldn't make any difference, the engine is just from a newer car, it won't change it passing smog. (FYI, we have none in FL. )
Old Aug 12, 2009 | 10:29 AM
deathsled's Avatar
injectors are the same I believe.
You literally just plop the engine into the AP1 and hook it up.
Old Aug 12, 2009 | 11:59 AM
JLUDE's Avatar
So the AP2 tranny and rear end are the same ratios and gears?
I'm doubting this since that would mean the AP1 would be capable of a higher top speed at fuel cut in 6th gear.
Old Aug 12, 2009 | 12:19 PM
The Ap2 tranny is a little stronger than the Ap1; the gear ratios are a tad different as well. Don't quote me on the gears though I can not recall correctly.
deathsled's Avatar
who said that?
The rear ends are all a 4.10 gear regardless of year.
The AP2 tranny is geared significantly differently than the AP1. 1-4 are shorter and 5-6 are taller.
Old Aug 13, 2009 | 04:29 AM
JLUDE's Avatar
Originally Posted by deathsled,Aug 12 2009, 12:19 PM
who said that?
So there may be a real benefit to using the AP2 tranny on the F20C motor...hmmmm. I would like shorter low gears.
Old Aug 13, 2009 | 07:28 AM
Mike21's Avatar
not worth the cost of a new tranny for slighly different ratios... unless you blew your tranny and are looking for a replacement.
Old Aug 13, 2009 | 11:07 AM
JLUDE's Avatar
I've never heard of anyone blowing a transmission on a street driven S2000 yet. I'm sure there are people who have though.
BuBuS2k
Aug 12, 2009 07:28 AM
s2ksang
Apr 8, 2009 03:57 PM
helothere
Apr 19, 2006 07:06 AM
