Question
Old Feb 28, 2005 | 06:35 PM
jiggagnome's Avatar
Default Question
I was driving today and coming to a stop put the clutch in and my car was idling really low and slightly rough and all of a sudden just died. My question is should i be concerned or is this something that just happens time to time
thanks for the help
Old Feb 28, 2005 | 07:14 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Whack the map sensor !!!
Old Feb 28, 2005 | 07:16 PM
YellowS2kPwr's Avatar
It might also be cylinder compression loss, please check your compression (not too expensive)
Old Mar 1, 2005 | 01:15 AM
aris's Avatar
I though the map sensor problem was solved for the MY03
Old Mar 1, 2005 | 07:48 AM
jiggagnome's Avatar
Thanks guys for the replies, I was wondering if it was the dreaded Map whack, but yes it did start right up after the incident.... a little bit of a struggle but not much, and has been fine since. Hmmm, Yellow s2kpwr where would i go about getting my compression checked? again thanks alot for the replies
Old Mar 1, 2005 | 12:09 PM
steven975's Avatar
my car was doing that last week. it would drop to like 3-400rpm when going back to idle and would have stalled out if i had not held the gas to keep it from doing so.
I pulled over and disconnected the map sensor. i gave it 2 whacks with the butt of my pocket knife and the problem went away.
i believe that even the MY04s have the same MAP sensor as the 00-03s. they recently did an update to the MAP I believe.
you can have compression checked at any servicing place for like $50.
Old Mar 1, 2005 | 05:26 PM
rev_high_er
May 27, 2009 09:26 AM
StatixNWH
Jan 20, 2007 04:13 PM
silencertk
Jun 28, 2006 07:17 PM
s2kdarren
Mar 19, 2005 05:02 PM
Denniz
Dec 3, 2003 12:19 PM
