Question about burned clutches...
Old Jul 25, 2004 | 09:06 PM
Ludedude's Avatar
Administrator
https://www.s2ki.com/home/index.php?option=...id=42&Itemid=41
Old Jul 25, 2004 | 10:43 PM
FadiS2K's Avatar
no no, this noise isn't just between 3k-4k rpm...its on every gear.
Old Jul 26, 2004 | 03:14 AM
Bass's Avatar
if you're not slipping it's the TSB - print the TSB out and bring it to the dealer (another one) and ask them for thier opintion (spelled wrong) also hook up with your local club and find out some of the better dealer's in your area.
plan on spending between $1,200.00 to 1,500 on new one so agressively persure the TSB issue
Old Jul 26, 2004 | 04:50 AM
2kturkey's Avatar
Fadi, if you are still under warranty then it is definitely a TSB replacement.
If your warranty has expired I wouldn't worry about it as your clutch is still working fine. However, if you can't live the noise then you are going to have to get it replaced - still you can buy a lot of sets of earplugs for $1.2 - $1.5k
Old Jul 26, 2004 | 07:49 AM
Gernby's Avatar
Former Sponsor
Think about it... If it makes the noise at 3K-4K RPMs in every gear, then it is related to the TSB.
Old Jul 26, 2004 | 10:21 AM
pantyraider's Avatar
Confused by this statement........
Old Jul 28, 2004 | 01:45 PM
FadiS2K's Avatar
ermm, meant every rpm...
Old Jul 28, 2004 | 01:54 PM
hpark's Avatar
verify if clutch is slipping...at freeway speeds, floor the throttle...if the revs climb but speed remains constant, then time for new clutch
Old Jul 28, 2004 | 02:30 PM
S2K Mayhem's Avatar
FadiiS2K, if San Luis Obispo isn't too far for you to go, bring your S to me at Sunset Honda, 805-544-9500. If your car is still under basic warranty, less than 3 years/36,000 miles, warranty repair should be no problem. If your S was first purchased more than three years ago, I may still be able to do a goodwill repair for you. Just did one of these today for another guy who spends time on this board. We installed a replacement OE disc with an aftermarket flywheel & cover assembly which he supplied. You can reach me at extension 632. Let me know if I can help.
Paul B.
Old Jul 29, 2004 | 01:29 AM
FadiS2K's Avatar
it's warranty expired
i'll definitely call you up, Paul. Thanks.
hmm, i don't believe my clutch is slipping. i'll try that full throttle highway test. i doubt the speed will remain constant.
