Question about lowering springs
Old Jul 13, 2005 | 08:13 PM
dannnnny's Avatar
Default Question about lowering springs
I just recieved my Tein S-tech springs today and I'm hoping to have them installed very soon, hopefully by tomorrow if time permits! I've heard that after installing springs, I should have my S checked for alignment about 2 weeks later. But do I need any other accessories such as shocks or a camber kit? Specifically people with springs, what would you recommend? Or will I be in good shape without anything else? thanks.
Old Jul 13, 2005 | 08:20 PM
carrnut21's Avatar
i don't know much about lowering an S2000, but I thought the general rule was that you use a camber kit with a drop of 1.5 inches or more, but I'm not sure if that is right.
Old Jul 13, 2005 | 08:31 PM
RM 4 2's Avatar
I'm not sure about Tain, but I have Espelire and it drops the car around 1.3". I was able to get back to stock alignment, but of cause, I go with more aggressive set up instead. The stock suspension system is fully adjustable and, if I remember it correctly, can go + or - 3, so you have a very wide range to play with.
As for waiting before aligment, it depends on mileage you are going to put in, how hard you drive, etc, in those couple of weeks. Mine was still changing even couple of months has past, but I have a very short and easy commute, so yours might be varies. Be carful, though, spare some room for errors and don't go all-out 10/10 before aligment, you'll see how screw up it is once your car is on the machine.
Old Jul 13, 2005 | 09:06 PM
SIIK2NR's Avatar
A couple of days is fine...
No camber kit needed..
Old Jul 14, 2005 | 02:51 AM
vampire's Avatar
nothing's needed,, i didn't need any alignment on the tein's springs
Old Jul 14, 2005 | 06:23 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
"S" suspension is adjustable;no camber kit needed,can drop up to 3 inchs.
Just installed Kg/mm sport,no alingment yet,but recommended,after they settle,in a week or two !
Old Jul 14, 2005 | 08:07 AM
wanabe's Avatar
eibachs on mine...
let it settle a couple of weeks and had an aggressive street alignment done.
after the drop it rubbed on all 4- after the alignment no rubs ever in the rear and the fronts rub now only on big bumps
Old Jul 14, 2005 | 08:33 AM
TallyS2K's Avatar
Originally Posted by wanabe,Jul 14 2005, 08:07 AM
eibachs on mine...
Are you on the stock 16s? I would love to drop my car but I do not think I will be able to get into my driveway if I do...any bright ideas?
Old Jul 14, 2005 | 12:39 PM
1)Fix the driveway.
2)Park on the street.
3)Move somewhere else.
orbels2k
Apr 15, 2011 11:51 AM
bamm9245
Jun 12, 2008 09:24 PM
s2addict
Sep 12, 2005 05:07 AM
hansel
Jul 20, 2005 09:28 AM
tenblade2001
Jun 23, 2003 06:47 AM
