Question about U.K.alignment?
Old Aug 6, 2005 | 08:41 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Originally Posted by GTFCTIM,Aug 6 2005, 09:46 PM
United Kingdom
Excuse me Sir,I tought it was for Great Britain !!!
Old Aug 6, 2005 | 10:26 PM
GTFCTIM's Avatar
England please squire
Old Aug 7, 2005 | 12:10 AM
rworne's Avatar
Originally Posted by candyass,Aug 6 2005, 10:54 AM
I had the UK alignment done on a new set of BFG KDW and with mixed hwy/city/autox/2 track days I got about 12000 miles out of them so it is really not to bad and the improvement in handling makes it well worth it.
It makes me wonder how out of spec my alignment is. I've got almost 25,000 miles on the fronts and 15,000+ miles on the rears and I am still not yet down to the wear bars on my S-02's. Got tread across the entire tire too.
Old Aug 7, 2005 | 05:53 AM
JonasM's Avatar
Honda (UK) Recommended Optimum Specification
Front
Caster Left 6
Old Aug 7, 2005 | 05:59 PM
Thanks Jonas.
So,If I read those specs.correctly,the rear tires,should wear faster on the inside,right?That would be the "con"part.
Also,is it true,that the car tends to be "squirrely"at high speed,on the highway?
The place where I go,has a "Hunter"machine,do I have to translate those numbers?
Emil.
Old Aug 7, 2005 | 06:11 PM
JonasM's Avatar
I've heard that rears wear from the inside to begin with, so it probably just means that they will wear a little faster.
At freeway speeds (yesterday) I didn't notice anything different from normal as far as the car staying planted.
My dealer has the laser-equipped Hunter machine - I think the tech told me that it can be set to accept either format, but I gave it to you in both formats, so it shouldn't be a problem.
Hint to the tech: that's NEGATIVE 1 degree on the camber in front. The service writer was a little sloppy, and the tech came to tell me that he couldn't get the adjustment to go as far as POSITIVE 1 degree!
I'm planning on just watching the wear, and having the rears remounted as needed to keep it fairly even. With the mileage I drive, $24 each year to swap is no biggie.
JonasM
Old Aug 7, 2005 | 07:15 PM
LiQUiD iCE's Avatar
Anyone know if the Honda UK recommended alignment settings are the same for the AP2s?
I'm going to get an alignment this week and I was trying to figure out if the UK alignment would be a good idea on the AP2.
Old Aug 8, 2005 | 03:19 AM
gdonahue's Avatar
JonasM
I get all four tires remounted at every other oil change. I'm getting excellent tire wear. My commute to work is 30 miles and 25 of those miles are on the highway. The other 5 miles consists of some really good curves (one switchback) and elevation changes. I couldn't be happier.
Old Aug 10, 2006 | 12:56 AM
KWgpws2k's Avatar
Im lowered on koni + gc and i would like to know this also. Im looking to get an alignment on my ap2 because i just got a fresh set of re050s and the car has never had an alignment.
any advice on ap2 alignment specs?
Old Sep 28, 2006 | 03:43 PM
UCrazyKid's Avatar
Anyone have advice on the AP2?
