Question regarding shifting
Old Feb 27, 2012 | 10:24 PM
  #21
Hondaplease's Avatar
i usually shit between 3-4k rpm's. If you feel a bit notchy/grind between 1st and 2nd, one way around this is instead of shifting straight through to second, when you get into neutral position from 1, make a very subtle side to side motion then slip it into 2nd. This allows the synchro's do its work and smooths the shift.
Old Feb 27, 2012 | 10:59 PM
  #22
importrule's Avatar
Originally Posted by sn0wman
Also 1st to 2nd is always kinda bumpy. But when I shift at around 4000-5000 it feels a little smoother but I don't think that'll give me good milage lol.
so you're saying bumpy as in the shifter being bumpy/notchy/hard to get into 2nd or the car jerks when you let go of the clutch pedal after shifted into 2nd?
i shift at 1-2 and 2-3, i shift at 5500, then 3.5/4k for the rest of the gears.
and, in 6th @ 4k going 75mph is stock.
Old Feb 28, 2012 | 04:46 AM
  #23
takeshi's Avatar
What RMP's do you guys normally shift at?
There are countless prior threads identical to this one that you should refer to. I don't shift at a fixed RPM. It depends on driving conditions. Typically ~3K-4K.
Old Feb 28, 2012 | 07:44 AM
  #24
TougeS2k's Avatar
3k cold, 5.5 warm and 8.8-9k for funsies
Old Feb 28, 2012 | 10:08 AM
  #25
thomsbrain's Avatar
Also, I got the car used. I'm not sure if the previous owner installed gears? In 6th gear going 75 MPH I'm at 4000 rpm cruising on the highway.
That's about right for the stock gears. The S2000 is geared very short. Makes for buzzy freeway cruising.
Old Feb 28, 2012 | 11:41 AM
  #26
Syn's Avatar
Syn
Look up clutch fluid change--should help with the notchy shifting. Also a heavier shift knob goes a long way--I just went from a lighter-than-stock knob to a 1 lb and it feels nicer all around.
I reserve 3k shifting for when I'm next to a cop...otherwise it's always 4k minimum, tending more towards 5-6.
  #27
dfvs2k's Avatar
I shift b/w 3-3500K RPM regular driving. Spirited = 4-6k RPM
Old Feb 28, 2012 | 11:55 AM
  #28
XtbateU's Avatar
I don't shit in my s2000. Not once...not ever
Old Feb 28, 2012 | 12:38 PM
  #29
LeonV's Avatar
Holy shift! Nice catch.
Old Feb 28, 2012 | 02:56 PM
  #30
m55555's Avatar
I shift between 4-5K.
I tried a tank granny shifting at 3K RPM, and there was no benefits. No extra MPG, took more time to get places, and wasn't as fun.
