Question on test pipe.
Hi, since the test pipe is just a straight pipe. i was just wondering can i custom the pipe myself ? will it work exactly the same ?
without the need to get a branded one ?
thanks !
thanks !
test pipe replaces the catalytic converter, which restricts the flow of exhaust gases. If you built one, you will need to include a threaded hole for the O2 sensor. Personally I think the time it will take you to make one of these (it not just a straight piece of pipe.. has built in gasket, flange, O2 hole, and a bend in the pipe) won't be worth the $100 you will save by not purchasing a quality unit.
