Question on test pipe.
Old Mar 15, 2007 | 06:12 AM
el10034's Avatar
Default Question on test pipe.
Hi, since the test pipe is just a straight pipe. i was just wondering can i custom the pipe myself ? will it work exactly the same ?
without the need to get a branded one ?
thanks !
Old Mar 15, 2007 | 06:15 AM
SILAP1's Avatar
yes i had a custom one and it fit fine , there is a few little bends that need to be made just buy a megan non resonated t/p 100 with bolts and gaskets worth it to me .
Old Mar 15, 2007 | 06:16 AM
milkbubble's Avatar
I would just buy one.. There inexpensive and it would be less trouble. Also off of the header a round crush gasket is used. It might be hard getting the metal flange to the shape of it.
Old Mar 15, 2007 | 06:20 AM
el10034's Avatar
what does the hole on the test pipe do actually?
Old Mar 15, 2007 | 06:27 AM
vtec9's Avatar
test pipe replaces the catalytic converter, which restricts the flow of exhaust gases. If you built one, you will need to include a threaded hole for the O2 sensor. Personally I think the time it will take you to make one of these (it not just a straight piece of pipe.. has built in gasket, flange, O2 hole, and a bend in the pipe) won't be worth the $100 you will save by not purchasing a quality unit.
amusepanda
Apr 23, 2009 04:56 PM
gudetime/s2k6
15
Dec 12, 2007 08:53 PM
Saint555
Mar 21, 2007 05:48 PM
SpaZilla
Oct 26, 2005 11:17 AM
supman
May 5, 2004 05:47 PM
