Quick Oil Change Question
Old Apr 26, 2007 | 11:57 AM
Marrk's Avatar
Default Quick Oil Change Question
I just did an oil and oil filter change. Filled it with the recommended amount of new oil (I measured by the cup) and presoaked the filter. I started with a 5.5 gallon jug of oil, so I know how much went in. The thing is I don't see anything on the dipstick.
Fire it up?
Old Apr 26, 2007 | 11:59 AM
Sinji's Avatar
did you put the drain bolt back?
Old Apr 26, 2007 | 12:00 PM
Sinji's Avatar
5.5 gallons? not liters?
Old Apr 26, 2007 | 12:02 PM
silvers2k01's Avatar
Measure by the cup? wow...
If you cant see anything on the dipstick, common sense would say put more oil in til you do
Project22a's Avatar
Measured by the cup? Presoaked the filter?
Old Apr 26, 2007 | 12:04 PM
johnny's Avatar
cup?
as far as presoaking, do you mean the lubing of the rubber gasket?
Old Apr 26, 2007 | 12:07 PM
madkimchi's Avatar
yes you do need to fire it up before checking the dip stick. most of the oil is still sitting on top part of the engine. but 5.5 gallons and presoak the filter? all you do is put some oil on oil filter rubber gasket. and 5.5 quarts.
Sinji's Avatar
you're going to need anywhere from 4.5- 5.5 quarts depending on how much you have left over in the engine. usually you want to fire it up for less than a minute then check oil levels again. don't put too much oil in there so you dont bust the seals. good luck
Old Apr 26, 2007 | 01:22 PM
RedY2KS2k's Avatar
Fire it up?
How many cups did you put in?
Old Apr 26, 2007 | 01:31 PM
Marrk's Avatar
Well, I'm baffled.
I have put 5.3-.5.4 quarts (not gallons, my typo) in out of a 5.5 quart Castrol jug. That's the only oil that has gone in. The Owner's Manual says it should take 5.1 quarts.
I warmed it up to 8 bars, no warning lights. Took it for a 17 mph spin literally around the block, no warning lights, everything normal. Take it back, park it in the same spot, check the dipstick. I'll be damned if I can see any oil on the dipstick. I touch it to a Klleenex and it leaves an oil mark, but that could be off the head as I pull the stick out, right?
So. . . .
