Quick Q for those who drive S2K in winter
Old Jan 14, 2009 | 10:55 AM
imjimmylin's Avatar
Default Quick Q for those who drive S2K in winter
I've been driving my S2000 this winter and I was wondering if any harm can be done when hardened snow hits the bottom of the car. I normally try to follow the trails on the road and on the busy streets it's fine, but in residential areas when I'm driving around the snow tends to build up in between the 2 trails. Sometimes it scraps the bottom of my car. Can this harm anything? Should I bet more careful?
Thanks
Old Jan 14, 2009 | 11:04 AM
dparm's Avatar
You'll be fine, short of hitting some insanely big piece of ice...but that would likely smash up the front bumper first.
I go bombing through the alleys in mine, and yes, the section between the tire tracks is very high. I can hear it under me.
Old Jan 14, 2009 | 12:07 PM
EVAN&MONICA's Avatar
Should be Ok as long as you dont get high centered
be carefull out there in the snow... winter is a bad time to test your limits in an S2K. Good luck
Old Jan 14, 2009 | 12:16 PM
Sabre's Avatar
with the above posts.
I drive in the snow all the time and I scrape. As long as you avoid any large hardened chunks, you'll be fine.
Old Jan 14, 2009 | 12:47 PM
NoRawkus305's Avatar
Basically what everyone has mentioned. The hardened ice pieces are the ones you need to be very careful with. They can alone put a good scraping underneath your car creating a gash. Be careful and drive safe.
Old Jan 14, 2009 | 01:02 PM
PJCC's Avatar
Thanks
This car was made for that kind of conditions...
Old Jan 14, 2009 | 01:10 PM
Mr. Francesco's Avatar
You will be ok.
rk604
Jan 1, 2009 11:31 PM
STC1709
Oct 4, 2006 07:12 AM
CvMugen
Sep 8, 2005 04:26 PM
Sbeall
Feb 1, 2005 05:46 PM
NotoriousGQ
Jun 16, 2003 09:56 AM
