quick question
Old Oct 28, 2010 | 04:04 PM
s2000maniac's Avatar
Default quick question
i did the gravity brake bleed and also did my clutch. i was superised of how fast the clutch fluid came out when i opened the bleeder. when i looked at the clutch fluid it was almost empty, so i added the ATE super blue and let it come out a little bit more and then i closed the bleeder. now the clutch padel feels "soft" sort of like smooth when i push it down. is that normal?
Old Oct 28, 2010 | 04:52 PM
RedY2KS2k's Avatar
It's hard to tell from your description.
spa01s2k's Avatar
Sounds like you may have let a little bit of air into the line. Re-bleed and see if it gets better.
When you say "so i added the ATE super blue and let it come out a little bit more and then i closed the bleeder", it sounds like you didn't let the new fluid make it all the way down. Make sure you are seeing new fluid before closing the bleeder.
Old Oct 28, 2010 | 05:04 PM
yea the new fluid came out from the bleeder, i had a 10 inch clear hose attached to the bleeder.
Old Oct 28, 2010 | 06:47 PM
Dr. Gonzo's Avatar
Did you keep topping off the original fluid?
If you didnt then you could have got some air in it.
Usually you can really tell if theres air in there as theres usually almost no pressure in the pedal.
Old Oct 28, 2010 | 08:34 PM
yes i topped it off twice
its something like that.....like the clutch has no resistence....b4 it was kinda hard to push....now its like "soft'..
i guess i'll try the re-bleeding it
Old Oct 28, 2010 | 09:00 PM
oemk's Avatar
im just got my s2k so i dont know how to do it the s2k way but the way i do it is after you fill in the fluid, step on the clutch about 5 times, open up the bleeder to push the air out then tighten it, and repeat the process (step on the clutch 5 times again and bleed it again) Add in fluid in between each time until it seems like theres no more air in there or when the clutch feels firm and "normal" again
Old Oct 29, 2010 | 07:28 PM
Robert O's Avatar
If you bled the reservoir down below the bottom outlet orifice at either time during your bleed process,it likely got some air into the system.In that case you'll need to simply top off the reservoir near the top and repeat the process a few times taking care not to bleed it past the point where the reservoir still has an inch or so level before refilling and resuming the bleed operation.An assistant is most helpful doing this.Well ....a good assistant.
Rat
Oct 26, 2016 03:08 PM
bbak11010
Mar 14, 2009 10:47 AM
ericshun
Jul 15, 2007 10:04 PM
03S2kStud
Jan 12, 2007 04:56 PM
mav
May 20, 2005 12:38 PM
