Radiator Cooling Plate...
Old Jul 9, 2004 | 09:28 PM
TunedS2000's Avatar
Default Radiator Cooling Plate...
do they really work and what one works/looks best? I know of two the APR one and the SP engineering one.
Old Jul 9, 2004 | 09:59 PM
ideugene's Avatar
dont really know if they work... but they sure look good! i bought the one from 4ig a while ago used off another member but cusco also makes a blue one that looks really good! theres also a bunch of people that have carbon fiber ones as well as the aluminum ones... good luck with your decision!
Old Jul 10, 2004 | 02:08 PM
TunedS2000's Avatar
anyone els with info?
Old Jul 10, 2004 | 04:46 PM
reds2's Avatar
Like this.
Rad Plate
Old Jul 10, 2004 | 05:47 PM
Russ's Avatar
The degree to which they work depends mainly on the type of intake
you're using. If you're running a short ram, you'll want to avoid such a modification because it forces most of any incoming air entering from the front fascia directly towards the radiator and away from your filter. The photo
above is an example of a properly designed radiator cover plate. It still allows
air to enter the stock airbox.
Old Jul 10, 2004 | 09:50 PM
TunedS2000's Avatar
I have the comptech CAI...
Old Jul 12, 2004 | 06:43 AM
reds2's Avatar
If you have the Comptech, go for a Cusco one. It doesn't have the hole for the snorkle and it comes in blue It should cost you about $100.
Old Jul 12, 2004 | 07:46 AM
wannabuy's Avatar
I went with a carbon fiber cover.
Old Jul 13, 2004 | 12:56 AM
TunedS2000's Avatar
Which ones have the hole (so I know not to get those)?
King Tut
May 30, 2016 11:01 AM
F1fletcher
Apr 26, 2006 06:17 PM
NNervous_R
Jan 29, 2006 04:07 AM
kctham
Mar 9, 2005 01:24 PM
Clayman
Nov 21, 2004 06:16 PM
