radiator fluid question
Old Jan 23, 2005 | 06:41 PM
RACER's Avatar
I just checked mine, it is green. The Helm manual shows part # OL999-9001 Honda All Season Coolant/Antifreeze Type II.
You be having the right stuff bro
Old Jan 23, 2005 | 06:44 PM
RACER's Avatar
Originally Posted by Stratocaster,Jan 22 2005, 09:09 PM
Yes. Make sure you get the right stuff. Honda sells is pre-mixed. It is blue and not green.
Are you sure your not using windshield washer fluid
Old Jan 23, 2005 | 09:42 PM
xviper's Avatar
Rumour has it that Honda felt that their Type II fluid (green) was too confusing since Type I ("normal" anti-freeze) was also green. If this is true, then I think you will continue to see green Type II till all current stock is used up. Now, the interesting question would be, "Why the heck didn't Honda make their Type II fluid ORANGE like everybody else?" When orange fluid leaks or spills, it looks green. So, when blue fluid leaks or spills, will it look green?
The expansion tank is for ............... well ................... EXPANSION! As the engine heats up, you'll see a higher level in the reservoir. As it cools, the level will fall. The whole idea is to keep the outlet (at the bottom of the reservoir) always covered with fluid. Below the "min" line when HOT may be too little and you risk air being drawn into the cooling system - a bad thing. Above the "max" line when COLD may be too much and you risk fluid being puked out of the reservoir - another bad thing. Keeping the COLD fluid level someplace between the two lines is fine.
(Yeah, I know. This is kinda what RACER already said.)
AP1EM1
Mar 20, 2015 01:15 PM
ookielookie
Feb 25, 2013 05:41 AM
ziggy[x]
Feb 17, 2010 08:38 AM
rikhemi
Dec 8, 2006 12:48 PM
