Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
Radiator Fluid
Old Feb 15, 2010 | 07:12 AM
ziggy[x]'s Avatar
Default Radiator Fluid
I was just wondering about radiator fluid since mine is a little on the low side. Can I just top it off with any radiator fluid that is green? Or does honda use some kind of special antifreeze that should not be mixed with other stuff?
Old Feb 15, 2010 | 08:12 AM
S2S's Avatar
S2S
ap2's usually use a long life coolant that is blue in color and you cant mix it with others. its expensive so if you dont want to use it you would have to completely flush the system before you added anything else. although i recommend using the OE coolant.
Old Feb 15, 2010 | 06:42 PM
ziggy[x]'s Avatar
but my radiator fluid is green not blue? unless im somewhat colour blind
Old Feb 16, 2010 | 01:37 PM
S2S's Avatar
S2S
if its green and you sure its green then use green.
NEVER MIX COOLANT IF THEY ARE DIFFERENT COLORS CAUSE THEY DONT MIX AND START TO GEL UP AND BECOME UNABLE FLOW PROPERLY!
Old Feb 16, 2010 | 02:11 PM
s2000_vtec_mike's Avatar
THIS! Happend to my friend!!!!! He had to change all the lines ALL!!!!!!!
Old Feb 16, 2010 | 02:18 PM
SteveC's Avatar
I'm glad I read this
Old Feb 17, 2010 | 08:38 AM
ziggy[x]'s Avatar
Thanks for your help s2s, I just found out that the s2000 (or mine in particular) takes Honda type 2 radiator fluid. I just bought some from the honda dealership and its the same colour with what i currently have in the car.
ookielookie
Feb 25, 2013 05:41 AM
rikhemi
Oct 26, 2006 12:31 PM
dmfitz82
Mar 8, 2006 07:52 AM
03s2kman
Jan 23, 2005 09:42 PM
