It raised ud--Dammit!!!
Old Dec 11, 2002 | 09:33 AM
Kekoa's Avatar
Default It raised ud--Dammit!!!
Have any of you guys out there installed a lighter exhaust than stock and notice a larger rear wheel well gap?? Well I did I had a custom exhuast installed that weighs approximately 40 lbs. The ride heigth was perfect with the stock exhaust, but has now noticeably raised up. FYI I'm running KG/MM race springs.
Old Dec 11, 2002 | 10:04 AM
Schatten's Avatar
custom exhaust that weighs 40lbs? the stock one weighs 54lbs. so there's not that much difference that should cause a gap in your ride height, especially with the kg/mm's.
Old Dec 11, 2002 | 10:49 AM
Kekoa's Avatar
[QUOTE]Originally posted by Schatten
[B]custom exhaust that weighs 40lbs?
Old Dec 11, 2002 | 10:52 AM
Konrad's Avatar
Having removed the spare, tools and adding a Ti exhaust there was not a real large difference in the way my car sat above the rear tires. And this was about a 70lb. reduction but withTein RA's. I would suspect you just did not pay real close attention as to the actual ride height before the new exhaust.
Konrad
Old Dec 11, 2002 | 12:23 PM
MajorHavoc's Avatar
I think you just need to drive around the block to let the suspension settle back down. I assume you raised the car to install it!!
Old Dec 11, 2002 | 12:30 PM
turbo_pwr's Avatar
I agree you might not have noticed it before that is all. I have single Amuse and no spare and it looked the same to me as it did before
Old Dec 11, 2002 | 12:57 PM
Kekoa's Avatar
[QUOTE]Originally posted by MajorHavoc
[B]I think you just need to drive around the block to let the suspension settle back down.
Old Dec 11, 2002 | 03:47 PM
Destiny2002's Avatar
[QUOTE]Originally posted by Kekoa
[B]Have any of you guys out there installed a lighter exhaust than stock and notice a larger rear wheel well gap??
Gixerthou
Jul 7, 2014 09:31 AM
sspicollo8
Apr 9, 2008 06:00 PM
S2kracka
May 8, 2005 01:50 PM
R3dLiNe9k
Jul 14, 2003 12:10 PM
ricosuave
Aug 12, 2001 05:44 AM
