Rear camber adjustment...
Old Apr 20, 2005 | 08:35 AM
INVIDIA's Avatar
Default Rear camber adjustment...
Here is my problem, I have gone through 3 sets of 285/30/zr18 in 24,000 miles and i'm sick and tired of it. I have read almost every post on camber and I am still lost. It is to my understanding that you can adjust the camber but it is limited. The bolt that you make the adjustments on, could anyone post a pic or give me an idea on how to do this? Or would it be better to just take it to a good show and have them work on it? If that is the case, what specs should I give them?
Thanks for the help in advance.
Kyle
Old Apr 20, 2005 | 09:03 AM
dlq04's Avatar
I would recommend you find the very best alignment shop in your area. Setting camber, caster, etc. can be tricky on these cars. Especially if someone has been dinking around with the settings to begin with.
As for settings, here is S2000 Original Wheel Alignment
Camber
Front -0 deg 30 min
Rear -1 deg 30 min
Caster
Front 6.0 deg
Total Toe Front 0 mm
Rear In 6 mm (1/4 inch)
Here are the settings I use and like per UK TSB Wheel Alignment Recommendations
Honda UK settings are published in degree/minutes and some machines take inputs in decimal degree which is translated by = sign.
Camber
Front -1 deg 00 min
Rear -2 deg 00 min
Caster
Front 6 deg 45 min = 6.75
Old Apr 21, 2005 | 12:29 PM
INVIDIA's Avatar
Thanks a lot for the great tip, sounds like a plan as soon as I get home from college.
Thanks,
Kyle
SPLNDID
Mar 14, 2010 02:19 PM
02S2Grand
Jun 7, 2008 05:12 PM
irock aypee one
Dec 16, 2006 11:46 AM
S2K:-)
Apr 13, 2006 08:31 PM
Squeezer
Mar 28, 2003 09:32 AM
