Rear Window Replacement?
Old May 21, 2010 | 09:07 AM
S2KBlack04's Avatar
Default Rear Window Replacement?
My rear window shattered, what is the best/easiest (or cheapest) way to replace it. Is it a possible DIY or no? TIA
Old May 21, 2010 | 10:23 AM
Mike21's Avatar
good luck. you'll most likely need a new top. the only way to install a new rear glass properly would be to remove the top.
my plastic rear window cracked in half a few months ago. i got a new sheet of clear plastic(boat window material) and cut out a bigger portion and double-sided taped it on temporarily for a few days. i took the car to an upholstery shop and the labor to remove the top, sew the new window on, and put it back on was $600. I found a perfect condition ap2 top with a glass window and had them install it. $750 total(got the top for super cheap).
I know this isn't your situation, but it might help a bit.
Old May 21, 2010 | 01:20 PM
zoomspeed05's Avatar
i have a extra rear window off my old soft top pm me if you want it "i give you good deal" lol
Old May 22, 2010 | 10:08 AM
S2KBlack04's Avatar
So I guess it's just better to replace the whole top...damn
EDIT: What if I just went for the hard top? Could I just put the soft top down and install the hardtop? Also, where can I get the OEM hardtop?
ness1216
Jan 25, 2008 07:50 PM
hokiemax
Nov 26, 2007 01:10 PM
exb00st
Dec 29, 2005 11:46 AM
gt489
Sep 14, 2005 06:13 PM
stuartlong
Apr 21, 2005 08:47 PM
