removing badge on trunk
Hi,
I want to remove the rear H badge and replace with a red one, can anyone tell me how to do it. Is there is an easy way of doing it with out damaging the trunk?
thx,
bigeggroll
thx,
bigeggroll
Use a spray first (adhesive remover) shoot, cant remember name, that helps to unglue part of it, and it wont damage paint. Then get dental floss and and put it uner the H and just wiggle and it should pop out with a little pressure behind the dental floss as well. Good luck!
Originally Posted by Elistan,Jun 8 2005, 01:16 PM
It's held on by adhesives only. (The front is held on by adhesives and clips.) Just use dental floss or fishing line or the like to cut through the adhesive.
Dental floss is what I'm sure the thiefs used on my car...
With my '00, both front and rear badges have those plastic posts. But only on the front badge are there clips that attach to the posts on the backside of the bumper. On the rears, the adhesive was the only thing holding the badge on - the posts are there for alignment only.
I wasn't aware that later models were different.
Same as in my car. The posts were only for alignment. I was able to use dental floss and some goo gone to remove the adhesive. The adhesive remover (goo gone or goof off) has to soak awhile, but eventually it all came off. No problems.
