Removing the boot cover - a solution.
Please forgive me if this has already been suggested. I am new to the forum and to the S2000.
I have a 2000 model, and the boot cover is a bear to remove. The little buttons that you have to pull straight back are near impossible, since cramming my hand over the roof and down to the button bends the boot cover up and puts tension on the snap.
My solution is pretty simple. I took plastic wire ties (the smallest zip type I could find) and made a loop, not around the button yet. Then, I tied a loop in a line through the zip tie loop. After that, I slipped the zip tie loop over the button on the cover and pulled it so that it is not too tight on the button, but will not slip off. I used one line, so that the ends are tied to the zip ties on the two center buttons (since those are the two that are hardest to get to. I just tuck the line into the top, under the cover.
Now, when I need to take off the cover, I can just pull on the line, without cramming my hand up to the buttons, and the snaps just pop off.
Again, if somebody has this already suggested, or if there is a better way to do it, I am open for ideas.
Pictures would be of assistance. Tks
Yep, yours and 50,000 others. At roughly 10 pounds apiece, that amounts to 250 tons of useless plastic. How many garbage truck loads is that?
fpresty
May 14, 2003 05:33 PM
