removing glue from interior
Old Nov 25, 2000 | 12:46 PM
loop303's Avatar
Can I use rubbing alcohol to remove glue from the vinyl interior? will it harm or discolor the vinyl?
I'm trying to remove some double-stick tape from the dash and am not sure how to remove the glue. Should I use goo-gone or something like it instead?
thanks
Old Nov 25, 2000 | 12:48 PM
2x6spds's Avatar
You might want to try lighter fluid using all appropriate precautions against open flames and other ignition sources.
2x6spds
Old Nov 25, 2000 | 12:50 PM
loop303's Avatar
thanks for the suggestion.
are you sure lighter fluid won't damage the vinyl?
Old Nov 25, 2000 | 01:07 PM
2x6spds's Avatar
Pretty sure. I'd try it if I needed to remove glue, and would be surprised and disappointed if it did damage the vinyl.
2x6
Old Nov 25, 2000 | 01:13 PM
PsychoBen's Avatar
loop,
Try the citrus stuffs like googone -- they really work wonders on adhesive residues and won't harm the material b/c they are "natural".
Old Nov 25, 2000 | 08:55 PM
song's Avatar
I've used rubbing alchohol twice with no ill effects. You should be fine with this.
My nosy daughter is looking at this as I type.
bcs
Jan 7, 2008 04:48 PM
S2KAYYY
Apr 24, 2007 07:16 PM
Charly
Aug 4, 2003 04:35 PM
Bozeman
Jun 5, 2003 04:41 AM
redleader
Feb 26, 2001 01:13 PM
