Removing rust from front grille?
Old Apr 22, 2003 | 06:22 AM
Russ's Avatar
My Grille Tech grilles took a beating this winter and I didn't notice the discoloration until a few days ago when the sun finally appeared (after a long winter). Is there any topical solution I can rub across the steel to return it to its original silver finish? Otherwise, I am going to paint 'em black. I'm just wondering what I can use that won't damage the finish (if I got sloppy). I intend to keep the grille on while (hopefully) removing the discoloration. It's not actual flaking rust, just a light reddish-orange discoloration that has seemed to lay atop the once shiny silver finish.
Old Apr 22, 2003 | 06:33 AM
RARE M5's Avatar
Russ, I will try no abrassive cleaner first and work your way into more strong cleaner. If you think that stain is light rust then try rub with dab of Coke or Pepsi. Acid from coke actually dissolve rust. (Don't try that with Diet Coke, just kidding ) Seriously, coke works on removing rust.
Good luck.
zeroptzero
Feb 1, 2016 12:58 PM
Fatbloke
May 26, 2010 09:07 AM
ghettocrxsi
Sep 4, 2009 04:39 AM
andy2000
Jun 27, 2009 06:55 AM
ROONEY
Jun 24, 2009 01:27 PM
