Replacing your convertible top with a Robbins Top
With 1 week in direct sunlight, tops should be stretched enough (at least in the Carolina's one week is enough). If anyone in the Carolina's or Virginia is interested in having a top installed, please feel free to PM or email me (TPhongprija@yahoo.com).
I've read some conflicting things. Obviously in this DIY, he has taken apart a lot of the interior but I've read other posts say that all you need to take out is your tray and your seats for better leverage. What is exactly required to take out and what is optional?
I just finished this job on My '04 using this post as a tutorial. Lot'sa time but well worth it. The pics and description are spot on. Thank you soooo much for taking the time to document and post this. Fantastic!!!!
Marcos
Ps: the top was very tight as mentioned by many folks. I used a heat gun to warm the top, concentrating on the seams, for aprox 5-10 minutes after which I was able to pull the top as well as use the motor and get it latched. Hope that helps someone out there.
Marcos
All the other trim removal is needed to get the roll bars out of the way.
I assume you are talking about the header bow, if so, use contact cement. Worked for me on 40+ tops with no issues to date.
Originally Posted by twrmnd' timestamp='1410675341' post='23330036
First, thank you op for making this diy, helped me a lot during the install.
I have one problem, my front corner flaps are not secured. I was wondering what you guys used to secure/seal them?
