Required Maintanence Questions
Old Apr 19, 2004 | 12:19 PM
Be3LiCiOuS's Avatar
Default Required Maintanence Questions
As some of you guys know, i just bought MY02 and it had 25,5xx miles on it.
I'm just wondering when would be a good time to get some scheduled maintanence done.
- Valve adjustment
- transmission fluid
- when changing oil (i will do this myself) change it with syntethic oil?
anything else i'm missing please add to the list for me, since i am a new S owner.
Old Apr 19, 2004 | 12:27 PM
ruexp67's Avatar
As it's new to you, I would service it immediatly as you don't know how well it's been maintained to this point.
I would do, Diff AND tranny fluid. I would also check the condition of the brakes and tires. It wouldn't hurt to bleed through the brake fluid (and Clutch master cylinder fluid too.) Also do the oil at the same time.
The general rule of thumb is to wait to go to synthetic until the car has fully broken in and has stopped burining oil. Usually around 10,000mi. As you are well beyond that, Synthetic would be a good choice IMHO.
I have no input on a valve adjustment.
Also, have your alignment checked and make sure your tires are all on correctly, the correct sizes, and not worn.
Old Apr 19, 2004 | 12:46 PM
Be3LiCiOuS's Avatar
thanks man.
just found this on s2ki:
Maintenance Schedule for Extreme Conditions.
This schedule is to be followed if you drive in one or more of these conditions most of the time:
Trips of less than 5 miles (less than 10 in freezing weather)
Extremely hot weather (over 90 degrees F)
Extensive idling or stop-and-go driving
Trailer towing, driving with a car-top carrier, or driving in the mountains
Muddy, dusty, or de-iced roads
3,750 mi/6,000 km
Replace engine oil and filter.
7,500 mi/12,000 km
Inspect front and rear brakes.
Check tire inflation and condition.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
11,250 mi/18,000 km
15,000 mi/24,000 km/1 yr
Replace air cleaner element.
Check parking brake adjustment.
Replace rear differential fluid.
Lubricate all hinges, locks, and latches with multi-purpose grease.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
#Inspect exhaust system.
#Inspect fuel lines and connections.
Check all lights.
Inspect the underbody.
# = See information on maintenance and emissions warranty, last column, page 151 of your owner's manual.
18,750 mi/30,000 km
22,500 mi/36,000 km
26,250 mi/42,000 km
30,000 mi/48,000 km/2 yrs
Check all lights.
Inspect drive belt.
Replace dust and pollen filter*.
* = See dust and pollen filter on page 187 of your owner's manual for replacement information under special driving conditions.
33,750 mi/54,000 km
37,500 mi/60,000 km
41,250 mi/66,000 km
3 years
Replace brake fluid (independent of mileage).
45,000 mi/72,000 km/3 yrs
Check all lights.
48,750 mi/78,000 km
52,500 mi/84,000 km
56,250 mi/90,000 km
60,000 mi/96,000 km/4 yrs
Check all lights.
Inspect drive belt.
Replace transmission fluid.
63,750 mi/102,000 km
67,500 mi/108,000 km
71,250 mi/114,000 km
75,00 mi/120,000 km/5 yrs
Check all lights.
78,750 mi/126,000 km
82,500 mi/132,000 km
86,250 mi/138,000 km
6 years
90,000 mi/144,000 km/6 yrs
Check all lights.
Inspect drive belt.
93,750 mi/150,000 km
97,500 mi/156,000 km
101,250 mi/162,000 km
105,000 mi/168,000 km/7 yrs
Replace spark plugs.
Inspect valve clearance.
Check idle speed.
Check all lights.
108,750 mi/174,000 km
112,500 mi/180,000 km
116,250 mi/186,000 km
120,000 mi/192,000 km/8 yrs
Check all lights.
Inspect drive belt.
9 years
120,000 mi/192,000 km/10 yrs
Replace engine coolant, then replace every 60,000 mi/96,000 km/5 yrs.
i should have searched. anyways, when i bought the car it was certified from honda so it went through their 150 point check so i should be good right? if there are any problems that i notice i'll be sure to bring it to Honda's attention.
Old Apr 19, 2004 | 02:28 PM
allkingz's Avatar
Changing the fluids wouldn't be a bad idea.
fallen612
Sep 25, 2009 07:37 PM
fromthegut
Jan 2, 2007 08:43 AM
Spec_Ops2087
Mar 25, 2006 05:36 PM
ScottB
Mar 26, 2004 08:10 AM
Squeezer
May 22, 2001 12:30 PM
