rev matching
Originally Posted by asdfg123hk,Jul 21 2005, 02:57 PM
but if we don't rev match then aren't we braking with the engine and it's bad if we do that a lot?
Originally Posted by vojm17,Jul 21 2005, 02:14 PM
Sorry i'm new at driving stick, but when you rev match, are you suppose to just side step off the clutch and it'll be smooth or are you suppose to release it somewhat slowly?
Originally Posted by rhood,Jul 21 2005, 03:05 PM
Practice it. The more you do it the better and smoother you will get. Soon you will be so smooth at it you won't even jerk your girlfriend's head forward. . . . uuuuggghh!!
The engine produces more horsepower when it is spinning at 6000rpm than when it is spinning at at 1000rpm.
An important time to rev match is when you are slowing down while racing.
For instance, if you brake for a sharp curve, downshift and exit the curve with the engine at a low rpm, you will be slow.
On the other hand, if you downshift and engage the transmission while the engine is spinning quickly, you will be faster.
The rev match allows this to happen. By raising the engine speed before engaging a lower gear, it allows you to be faster by increasing the speed of the engine immediately befrore engaging the transmission, thus engaging the transmission at at a higher engine speed.
The "heel-toe" move is sometimes used to both brake and rev-match simultaneously. For examples of this technique, watch the Best Motoring series of car racing videos from Japan.
Originally Posted by YellowS2kPwr,Jul 21 2005, 03:01 PM
Get off of it fast otherwise you'd be burning the clutch
rev matching = increasing revs to match the engine speed when shifting down or decreasing revs to match the engine speed when shifting up...smoother into the the next gear and decreases wear on the synchros.
Originally Posted by asdfg123hk,Jul 21 2005, 07:15 PM
you mean just drop the clutch? wouldn't that cause the car to jerk? or did you mean release it at a somewhat fast pace as to dropping it really quick?
Speaking of engine braking, I have always done that.... heel and toeing all the way to the a stop at redlights, stopsigns, etc.....
