rev matching
Old Jul 22, 2005 | 11:44 AM
  #41
xenosis's Avatar
so in another words. Power shifting is just jaming gears in?
for example... racing: whiling flooring it, when you shift you just jam it into gear????
what kind of maniac would do such a thing?
Old Jul 22, 2005 | 11:45 AM
  #42
PeaceLove&S2K's Avatar
A maniac who isn't driving his own car.
Old Jul 22, 2005 | 11:47 AM
  #43
Bullitt44's Avatar
Originally Posted by icecreamballer,Jul 21 2005, 08:37 PM
how do u do power shift?
kinda off topic, but is it bad to double clutch everytime i feel necessary when down shifting??
Power Shifting = foot to the wood will shifting never lifting.
* I would definity NOT recommend shifting in this manner unless you like to break things.
Double clutching the proper way will never hurt anything.
Old Jul 22, 2005 | 01:06 PM
  #44
slimjim8201's Avatar
[QUOTE=PeaceLove&S2K]QUOTE (if lookz kill @ Jul 22 2005, 02:22 PM)
is that true?...
when you're engine braking you don't waste gas?....
Old Jul 22, 2005 | 01:50 PM
  #45
ho2go's Avatar
I found a great article about double-clutching that I've had bookmarked for a while now:
http://www.vtec.net/articles/view-ar...rticle_id=3249
At first it took me a few read-throughs but it's really informative if you're patient & think of what's connecting/disconnecting as per the author's "diagram".
To summarize the article, you do not *have* to double-clutch with modern transmissions because your synchros will sort everything out, just as many people in this thread have mentioned. HOWEVER, you will save your sychros some wear if you double-clutch.
Also, single-clutch rev-matching (as has been proposed a few times in this thread, if I unerstood you guys correctly) does indeed make for a smoother shift but does not give that added bit of help to your synchros (which is certainly ok - after all, the synchros are there for a reason!) that double-clutching does.
So in conclusion (please correct me if I'm wrong!), both single-clutch rev-matching and double-clutching are acceptable and safe in modern trannys.
Old Jul 22, 2005 | 01:57 PM
  #46
YellowS2kPwr's Avatar
NO, POWERSHIFTING IS NOT JUST JAMMING IN THE GEARS W/CLUTCH. It's holding the gas to the floor while shifting. Jeez
Old Jul 22, 2005 | 02:00 PM
  #47
Will_ChinLee's Avatar
Good lord people. if you need to be asking about this stuff, save your car from some wear drive normally. Rev matching should really be used on the track. If your doing it on the streets than your driving too damn fast while coming into a corner.
Old Jul 22, 2005 | 02:14 PM
  #48
SIIK2NR's Avatar
Old Jul 22, 2005 | 06:05 PM
  #49
Woodson's Avatar
Old Jul 22, 2005 | 06:34 PM
  #50
xviper's Avatar
Originally Posted by Woodson,Jul 22 2005, 07:05 PM
^ I SECOND and THIRD this sentiment.
I wonder if most of these people even know what "rev matching" is and what it's for and what it truly does.
jal3lee, I would strongly suggest you ignore this whole thread. I would say 75% of what has been posted here is complete and utter CRAP! You would do far better to contact a good driving school to find out what "rev matching (both UP and DOWNshifting), double clutching, heel/toe" really is. Did you also know that you can combine some or all of these? I'm not going to even start to tell you which 25% you should believe. I'm not feeling that charitable today.
It has been absolutely excrutiating reading the information provided in this thread.
