Roll over bars
Old Sep 2, 2002 | 06:11 PM
trt944's Avatar
Default Roll over bars
While at the dealer the other night I saw that the "rollover bars" behind the seats are covered with plastic shrouds. Does anyone know what the bars look like underneath the shrouds; are they true roll over bars, adequate to use for propely anchoring a harness? I will be using my S2000 for track use, and always wear a five point harness, so I want to knbow how best to mount one. I'll swap out the seats for Sparco shells with harness cutouts.
Thanks
Old Sep 2, 2002 | 07:55 PM
swells65's Avatar
Have a look in the Racing section, there are plenty of posts re roll cages, ancorage points etc.
Old Sep 2, 2002 | 08:23 PM
Strike's Avatar
The built in roll hoops are indeed good rollover protection. However, before you even think about installing harnesses please see the comments in the following thread:
https://www.s2ki.com/forums/showthread.php?...?threadid=76744
Unless you're a midget you'll want to add an aftermarket rollbar before installing harnesses.
Old Sep 2, 2002 | 08:44 PM
trt944's Avatar
[QUOTE]Originally posted by Strike
[B]The built in roll hoops are indeed good rollover protection.
Old Sep 2, 2002 | 08:53 PM
Strike's Avatar
If you like having the harness I'd recommend an aftermarket rollbar. The bitterman bar, for example, adds something like 4-6 inches of height to your roll protection, which for most people, is enough to install harnesses safely. The main point is that you don't want to add harnesses with the stock roll protection because most people's heads are above those, especially after putting a helmet on.
Old Sep 3, 2002 | 07:07 AM
trt944's Avatar
[B]If you like having the harness I'd recommend an aftermarket rollbar.
Subalahoo
Mar 21, 2009 09:09 AM
nichigo
May 15, 2007 05:18 PM
gochuxsaurus
Oct 11, 2005 11:32 PM
minboost
Jun 13, 2003 10:15 AM
zero_to60
Jan 27, 2003 08:39 AM
