Rotors
Old Feb 25, 2006 | 10:56 AM
jdnissanz's Avatar
Default Rotors
Do Ebay rotors work ok with our Honda S2000s? If not which ones can I buy to use with new OEM Honda Brake Pads...Also, do perforamnce pads actually make a huge difference...
Old Feb 25, 2006 | 11:04 AM
04RioS2k's Avatar
if you do get rotors go for the slotted as I heard drilled is more prone to cracking, also ebay rotors probably work, just search for s2000 rotors and a bunch will pop up....
Old Feb 25, 2006 | 11:11 AM
SpeedxRacer's Avatar
OEM is your best bet.
Old Feb 25, 2006 | 11:40 AM
SaltyDog's Avatar
Slotted rotors tear up your pads. Drilled rotors are fine as long as they are casted with the holes rather than drilled after the fact. Also, the reason they crack is due to tremendous heat and pressure caused from track driving. They would be fine on the street, but then again, if all you do is street driving and a little track, then oem's is the way to go.
Old Feb 25, 2006 | 11:49 AM
Eluded's Avatar
The jury is still out on OEM but that would be my choice. OEM rotors with OEM pads.
Old Feb 25, 2006 | 01:16 PM
LT_s2k's Avatar
u cant go wrong with oem!!!
Old Feb 25, 2006 | 01:18 PM
passmans2kny's Avatar
power slot, oem fitment, drilled or slotted, i had em on my rx7 and they were great, the price is good too, those with some top of the line pads, prob wont be that much better than stock, but u know
Old Feb 25, 2006 | 01:23 PM
darkfx's Avatar
not always
Old Feb 25, 2006 | 01:26 PM
Sideways's Avatar
OEMs work great with early (less dust) factory pads.
Avoid the drilled:
Old Feb 26, 2006 | 09:36 PM
millertown15's Avatar
OUCH!!!
