RPM
Old Jan 29, 2006 | 09:44 AM
jdmgpw04's Avatar
Default RPM
on certain day when im driving and i get stock in traffic my rpm starts to go nuts.
i was driving in a mild traffic then on a stop light my car is in neutral the rpm stays at 1500 rpm then i press the gas a little bit then it goes back to normal around 900-1000. this happens every at every stop light.
i have search it here but i couldnt find any answer
Old Jan 29, 2006 | 09:48 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
It can be a learning process.
I would reset the ECU(3* fuse from top)and,give it time to learn;don't press the gas,(idle at a stoplight)even if it dies on you.
Old Jan 29, 2006 | 10:51 AM
Driv300mph's Avatar
I would just unplug the battery and reset the ECU that way. If that doesn't work, you might try an MAP Whack... just unplug and replug it back in (the plug that says "Denso" by the throttle body)
Old Jan 29, 2006 | 11:25 AM
kayvan_pour's Avatar
Banned
it's happened to me before... nothing to really worry about...
but I agree with Emil St-Hilaire if you want to fix it. Just follow his steps...
Old Jan 29, 2006 | 11:52 AM
jdmgpw04's Avatar
i have done the map whacked i guess i have to do the ecu reset
Sexi2k
Feb 16, 2015 02:46 AM
Spies
Oct 6, 2009 01:37 PM
kalibo
Sep 21, 2007 09:07 AM
osc
May 31, 2005 06:50 AM
high on nine
Jul 10, 2003 07:19 AM
