S2000 2004 1->2 shift grind
Old Jan 2, 2010 | 11:52 AM
JDMQuip's Avatar
Originally Posted by Henry Low,Jan 2 2010, 02:05 AM
Do you think it is manufacture design flaw?
It seems like many people are experiencing similar things...
It could be a couple things wrong. If the fluid change didn't help try changing your driving habits. Adjust the seat position closer so the clutch engages. If that doesn't work it could be your clutch master cylinder. It could be leaking causing your pedal to be stiff/not engaging all the way. If you remove your CMC you'll see a 'marble' like ball and it has a tendency to have a sharp point on it. Just simply file that down and re-install and it works wonders. If those don't work it's probably your synchro's going bad. I had my 2nd and 3rd gear go out at about 34k.
Old Jan 2, 2010 | 12:11 PM
J'sS2K's Avatar
90% of the time is the way you hold your shifter that cuases the grind! it happened to me when I first got my car! the other 10% is the transmission fluid!
Old Jan 2, 2010 | 01:22 PM
Chiro JW's Avatar
My 2005 does the same thing, I just bought it about a month ago. I will check/adjust the fluids tomorrow and post results.
Old Jan 2, 2010 | 02:28 PM
Henry Low's Avatar
Hi guys,
Thanks for all the replies. Its always amazes me that people would be kind enough to spend their time to give me help.
I have still yet to do the tranny/cluch fluid change yet however I brought the car to an autoshop that has alot of experience with Honda cars. The owner of the place test drove my car and reassured me that the syncros were still ok and it was not grinding, but simply it had to do with the notchiness of the shifter. He told me that tranny fluid change would help with that. He did mention that the clutch, though still grabbing fine, is getting old, which may explains the fact that any error in shifting or holding the shifter may cause a grind "easier".
I will make the change in fluids and report my findings.
I will also experiment with the way I sit and hold the shifter.
Thanks for all the help.
Henry
Old Jan 2, 2010 | 02:29 PM
Henry Low's Avatar
If you do not mind, how did you change the way you hold the shift that improved the problem?
Thanks in advance,
Henry
Old Jan 2, 2010 | 03:20 PM
elsinoreboy's Avatar
i had the same problem,and i was shifting the way i use to shift my civic,change the style of shifting,let it warm up a little in the morning and changed the oil and now is like butter,next will be taking out the shifter and lubricating inside it
Old Jan 15, 2010 | 09:07 PM
Henry Low's Avatar
Hi,
When you say changed the way you shift, what kind of changes did you make?
Thanks,
H
Old Jan 16, 2010 | 05:11 PM
S2Fire's Avatar
Banned
it happened to my04. i changed the fluid and it got better.
Old Jan 16, 2010 | 07:07 PM
sirbunz's Avatar
Happened to my '05 at 20k and to my '08 at 5k (beginning symptoms), both replaced under warranty by the dealer. Its on the TSB somewhere (according to the Honda tech). 2nd gear may also start to pop out as it gets worse. It feel like it took more shifting effort just to get it into 2nd without grinding. The throw also feels longer and sloppy compared to the others. Had to do with some sort of wear and tear problem with the syncro and gear set engagement.
04Mintcondition
Dec 3, 2018 06:46 PM
David A
Nov 15, 2006 11:48 AM
testingwaters
May 17, 2004 01:09 PM
Rane
Mar 10, 2004 06:48 AM
Chris Type R
Oct 2, 2003 07:13 AM
