S2000 a mid-engine car?
ok...help me out on this....how about some definitions for the cars below??
1903-08 cadillac...engine dead nuts in between the axles..[right under the driver]
1909-27 ford model t....engine well behind the front axle...
1924-30 bugatti t-35...[.same as above]
1965 lotus super seven..[same as above]
1958 porsche 356...engine completely behind rear axle...
1968 porsche 911 [as above]..
1958 panhard...engine in front of front axle....
1956 porsche 550...engine in front of rear axle
196? oldsmobile toronado...engine directly above front axle....
198?delorean..engine directly above rear axle....
indy stp turbine car....engine next to driver between axles....
if you can answer the above then you can make the call on a s2000.
Well there it is. The S2000 is a mid engine car. A front mid engine to be exact. Not to be confused with the traditional rear mid engine cars that most people are more familiar with.
Anyone dizzy yet?
Anyone dizzy yet?
Originally posted by Russian
Guys cmon, open up your hoods. If you see an enigne, you are looking at a front-engine car.
I think the post describing the Mercedes SLR's engine layout gives my thinking more credibility.
The basic reason why 50-50 is ideal is because during acceleration you want as much of the cars weight over the rear tires as possible. (we're talking rear wheel drive only here). And during braking you want as much of the weight over the fronts to give better traction while taking a turn.
