S2000 myths debunked
Originally Posted by S2Krazee,Dec 6 2009, 02:29 PM
I sincerely hope this is an attempt at sarcasm.
i own both cars at the moment and i can tell you the S is slower than the 370Z.
waaaaaay slower.
depends on what you are comparing to. The S2000 has abundant torque relative to my neighbor's 1998 Celica GTS, but has none compared to my bro's M3 ... so it's all relative.
Even horsepower, one could argue the S2000 doesn't have enough power, while others argue it's good enough ...
will be a never ending debate
Originally Posted by hammerzero,Dec 6 2009, 06:53 PM
same here.
waaaaaay slower.
waaaaaay slower.
those things are nothing without the sport package, nothing!!, hahahahaha
thank you!!!, finally, its all relative, that was the point of my escalade story, i was trying to draw people's attention to the fact that a vehicle with 400lb-ft of torque had a hard time keeping up with an s2000 operating below the powerband. never heard anyone say the escalade was lacking in torque
Originally Posted by mtgear1,Dec 6 2009, 10:54 PM
really? i have a hard time believing a 3,233lbs base model 370z with no limited slip differential and 50 series 18 inch tires (front , 45 series back) will be able to keep up with an s2000 around a tight circuit, much less a s2000 CR
The S2000 is a great car, but don't give it too much credit.
Originally Posted by mtgear1,Dec 7 2009, 01:21 AM
its an extra 95hp, and good luck putting all that extra hp down in the corner exit, and late braking into the corner with plumper tires and more weight .
agreed it is a great car, i dont think it gets enough credit, u think it was a small dot in ur mirror because it was purely your skills?, until u record lap time back to back S2000 and base model 370z u cant tell.
dont give yourself too much credit either, Mr Schumacher
Originally Posted by S2Krazee,Dec 6 2009, 01:05 PM
You need to crack open an old physics text book and brush up on your understanding of torque, and more importantly, its relationship to power.
You say "power determines torque at the drive wheels"... this is the most bass ackwards statement I have ever read.
Thrust at the ground = power/road speed (minus losses)
Power is considered work, which is equivalent to an amount of "moment" over a specific period of time.
If you know engine power and road speed, you know the thrust at the tire contact patch.
Thrust at wheels = power/speed
thrust in lb. = (horsepower*550)/(speed in ft/s) [multiply by ~.85-.90 to account for mechanical losses in the drivetrain and tire slip]
I'm rolling laughing at your claim that the 350Z is a momentum car. That is probably one of the most misinformed claims I have read on a forum in a long time. If you think the 350Z wont pull away from the S2000 on a track (especially out of low speed corners), then you have been around some very shitty Z drivers.
You sound like someone who has tracked your car once or twice... probably at an HPDE with 30 other inept drivers...
I'm sure someone there had a 350Z that they couldn't drive worth a damn.
Spend some more time at the track with COMPETENT drivers. Make your way up into some of the faster bracketed run groups. Run with some spec miatas durring practice. Run with some heavy GTU cars with loads of torque and see what happens.
Come back in a few years after you've got a solid 25 track days under your belt and try to support these same claims.
Try again...
