S2000 oil overfill
Old Jun 18, 2008 | 11:04 AM
AeroS2000's Avatar
Thumbs up S2000 oil overfill
hi , ived recently changed my engine oil. i put in about 5.5 quarts of Mobile1 10w-30.
the dipsticks says its right at "H". is that an overfill and should i drain some out?
Old Jun 18, 2008 | 11:06 AM
shotiable's Avatar
my understanding is that H is where its supposed to be. the maximum level of oil you can put.
i think you have .4 more than you need though, last i heard 5.1 is the amount needed for our engine. which reminds me i gotta top mine off
Old Jun 18, 2008 | 11:10 AM
TubeDriver's Avatar
That should be fine. Is that dipstick amount when the engine is hot or cold? If hot, you are 100% fine, if cold you may want to drain .5 qt although I probably would not worry about it.
Old Jun 18, 2008 | 11:15 AM
AeroS2000's Avatar
i thought when its cold, it gets a higher reading. but yea, hot is right at H and cold is a lil over.
Old Jun 18, 2008 | 11:56 AM
TubeDriver's Avatar
That makes no sense. Oil expands when it get hot so the level should read higher when the engine is hot. But you have to wait 5 minutes after turning the engine off in order to let the oil drain down into the oil pan to get an accurate reading. If you are a little over the H mark when the oil is cold, I probably would loosen the drain plug and let .5 qt drain out. Actually, on second thought I probably would not bother.
Also make sure you are on a flat surface when taking a reading. It will not be accurate if you are parked on a hill.
Old Jun 18, 2008 | 12:20 PM
mk3valver's Avatar
ruinded the cat in my golf by overfilling, made my vectra go into safe mode by doing the same!!! i don't learn quickly lol
drain a bit.... then you don't have to worry about it
Old Jun 18, 2008 | 12:23 PM
teanza's Avatar
that tiny extra bit of oil will be burned-off before you know it. even if these didn't burn any, doesn't matter. it's not 2 much; don't go thru the hassle trust me!
~tina~
Old Jun 19, 2008 | 06:02 PM
s2kdriver80's Avatar
I've been putting all 6 qts in at every oil change for a while now since the engine tends to burn oil. No problems. I wouldn't put any more than that though.
Old Jun 19, 2008 | 06:16 PM
daktruckie99's Avatar
You're fine.
Old Jun 20, 2008 | 05:57 AM
N2oExpresS2k's Avatar
I used to do the same but it's really unecessary. Last oil change I put 5 and it was 3/4 of the way up the shaded area of the dipstick cold. You lose a bit of power and risk other problems when you overfill it so much.
