S2000 oil overfill
Old Jun 20, 2008 | 10:11 AM
  #21
JackS's Avatar
0.1qt. equals a little over 3oz (90mls).
Old Jun 20, 2008 | 10:41 AM
  #22
vtec9's Avatar
Originally Posted by aLcm,Jun 20 2008, 02:05 PM
i cant figure out how much is .1 .can someone tell me ? i only put it 5 quarts because im scared i might overfill it if i try to put in 5.1.
also... when is the oil reading more acurate? early in the morning when it hasnt been driven. or after it has been driven to wait a couple mins to read the amount?
You're supposed to allow the engine to warm up completely. Then shut it off, wait 5 minutes, and then check the oil level. At this time it should be between the L and H.
5 qt in my S puts the level about .6 qt short of the H.
Old Jun 20, 2008 | 01:13 PM
  #23
LostMotion's Avatar
5 quarts has never been enough for me. 5.5 to 5.6 takes me to about 4/4s to 7/8s of the way to H. Engine fully warmed.
Old Jun 20, 2008 | 04:16 PM
  #24
Berner9's Avatar
When I fill my 07 it is right at the H with 5 quarts. Thats after letting it really drain for a good 30 mins or longer.
I was at the track tuesday and my buddy said everytime around one of the turns when I braked it would shoot out a white cloud of smoke. We figured it was oil splashing up. Anyone know?
Old Jun 20, 2008 | 04:28 PM
  #25
skier219's Avatar
When you change oil and filter, put 5 qts back in the engine. Let it run for a few minutes, then shut off and walk away. A few hours later, or maybe the next morning, check the level *cold* before starting it again, and add any oil as needed.
Checking oil level on a warm engine, or on ground that is not level, seems to be the typical way people go wrong and add the wrong amount of oil.
Old Jun 20, 2008 | 04:40 PM
  #26
Blacknot's Avatar
Old Jun 20, 2008 | 05:19 PM
  #27
a_zepeda926's Avatar
Originally Posted by N2oExpresS2k,Jun 20 2008, 09:03 AM
All matter expands as it heats up.
actually water expands when frozen...
Old Jun 20, 2008 | 06:09 PM
  #28
MitsukillinS2K's Avatar
your good just next time be more vigilant
Old Jun 21, 2008 | 12:43 PM
  #29
LostMotion's Avatar
Water is funny like that, one of the only substances to do it.
But it also expands slightly when it gets hot.
The problem with checking oil in a cold car is that more oil is the pan and not where it's supposed to be within the motor. That is why you check the oil level after running the car.
Peti
May 6, 2008 12:14 PM
el10034
Apr 29, 2007 07:24 PM
alex.stanley
Jul 12, 2005 01:14 PM
FormerH22a4
Apr 23, 2002 07:26 AM
DJHohum
Feb 20, 2001 11:32 AM
