S2000 Safety Features... what has changed?
i have done some searching and i cannot find anything that shows the history of the safety features on the s2000 and was wondering if anyone knew...???
I would like to know what the yr 2000 features where... that is what i have.. and then what changed or improved after that?? also does the 2000 model have the heavy duty side impact beams?? in the doors cause i was doing speakers today and didnt really notice anything in the door that looked beafy...
thanks!
thanks!
Also, the suspension on the AP2 was modified to be less sharp than the AP1, and more predictable to the average driver; reduced tendency for snap oversteer.
The AP2 suspension is explained here:
http://www.gtchannel.com/content.php?cid=17003
Originally Posted by HiPER,Apr 18 2008, 07:31 PM
06+ receives VSA (Vehicle Stability Assist). That is the biggest notable safety change since the start. 06+ also receives sensors in the seats for airbag deployment.
08 got a tire pressure monitoring system i think.
and the real spring rate thing is that it shifted stiffness ratios. the earliest were stiffer in the rear than in front, and the later models are stiffer in front than in the rear. 06-07 are the least stiff overall, i believe, but it's not leaps and bounds softer if you sum the stiffnesses (except if you consider the stiffest, the CR)
zeroptzero
Mar 24, 2016 05:52 PM
