S2000 weight savings.
A beefier front bar is probably the quickest and easiest fix but i'd recommend stiffer rear springs in conjunction with a softer/removed rear sway bar. Its that rear sway bar thats picking up the rear inside wheel.
Have you removed your rear sway bar?
So far, I don't push the car enough to get rear wheel lift problems, but I also have the N-0 coil overs.
I swaped a softer '02 bar for my '00 rear bar. Unfortunately i have yet to change spring rates but even now i can notice that i have quite a bit less wheel lift than before. I'll likely be making a spring change mid Jan in time for LS. But, i'm still undecided if i'm going to try and run with no bar and the corrosponding stiffer springs. From what i hear though thats really the way to do it.
Rylan, the corner weighting can't really do anything for the f/r weight distribution, only the balance between LF+RR vs. RF+LR.
Mike,
The problem is a basic one in the roll couple distribution (but you've got Milliken's book, you already knew that
). Because of your change in the balance of the car, it may be time for you to leave behind the paradigm of more tire in the rear for the S2000. Since your car already pushes, anything you do to the front to keep that back wheel planted (stiffer springs, bigger bar) will just make it push more. Unless....you add more tire along with the change.
A similar question was posed on another board in relation to this one:
http://www.corner-carvers.com/forums/showt...p?threadid=6235
The X factor in all this is shocks. The inside wheelspin issue is a problem most every autocrosser on R-compounds has faced at some point. The standard solution is a big front bar - but - shock tuning can do a lot for you. I've driven a few S2000s, and know that a car with the right shock valving and setup can out-handle and put power down better than another car with more swaybar and stock (or sub-optimally valved/tuned) shocks.
Mike,
). Because of your change in the balance of the car, it may be time for you to leave behind the paradigm of more tire in the rear for the S2000. Since your car already pushes, anything you do to the front to keep that back wheel planted (stiffer springs, bigger bar) will just make it push more. Unless....you add more tire along with the change.A similar question was posed on another board in relation to this one:
Originally posted by Mike Schuster
So stiffer springs than Ohlins' standard recommendation are needed for bumpy tracks if you want to lower the car much.
