S2000 weight savings.
Originally posted by SSK
How about going on a diet?
for example, If I were back at my college weight, that'd save me 30-40 lbs!!!
USA and Canada cars use smaller containers: USA 2.6lt, Canada 4.2lt.
Here are the things I have done so far to reduce weight:
Remove 8 gallons of gas 48lbs
Remove right seat 35lbs
JDM wheels and Michelin Cup tires 34lbs
Remove spare tire 25lbs
Remove tool box 7lbs
Remove washer fluid 5lbs
Remove floor mats and visors 2lbs
Remove cruise control 2lbs
Total 158lbs
Next on the list is a light weight exhaust and stereo removal for maybe 35-50lbs more.
Total 158lbs
I have installed or on order the following:
Amuse Dual R1 Ti catback exhaust = 35 lbs. saved.
Spoon header = 6 - 8 lbs. saved.
Regamaster Evo 16" wheels = 26 lbs. saved.
Pinnacle Brake system w/ "wave" rotors all around = 26 lbs. saved
No spare or tools = 32 lbs.
Not sure if I'll change the seats, but that would save another 30 plus pounds.
I won't go w/ the CF doors, hood, trunk lid, even though that would save better than 80 lbs. - just WAY too costly.
Need to shave 20 lbs. or so off my gut/butt.
EDIT: Forgot about the Star "lightweight" pressure plate. Can't recall exactly how much it saved, but I did weigh it and I think I recall that it was about 4 lbs. lighter. Also forgot about the OEM locking lug nuts (one on each wheel). I kept the "key" in the car in case of a flat and I have to call somebody to fix it out on the road. Wouldn't do much good if they couldn't get the wheel off
So that adds a few ounces.
I know that this has been a post before, but here's some weight savings!
http://www.wcmultralite.com
Originally posted by Mike Schuster
I was surprised also.
Factory S02 205/245 23.3/26.1lbs
Michelin Cup 225/245 20.5/21.4lbs
Factory 5-spoke (cast Enkei) wheels 17.8/18.8lbs
JDM 6-spoke (forged BBS) wheels 13.2/14.2lbs
On my scale the savings was about 8lbs per front, 9lbs per rear.
When I was 17 I remember using a turkey baster to empty out the contents of my CRX's washer fluid reservoir in high school shop class. Those were the days...
these days, if you want to be light, the secret is those carbon fiber hood rods...
Originally posted by 2kturkey
I had cause to refill my washer unit. It was totally empty and I ended up putting 7 litres of fluid in there to fill it.
Are those the 6-spoke JDMs? If so, how much did you pay for them (if you don't mind my asking) and from where/whom did you get them?
