S2000 weight savings.
Old Dec 4, 2002 | 10:18 PM
  #31
Mike Schuster's Avatar
I did a little more work tonight. On my '01 car, each factory front shock and spring assembly is 10lbs, each rear is 11lbs. A door speaker is only 1lbs. Each door trim panel is a 5lbs credit if you reattach the door handle and switch assemblies.
Old Dec 5, 2002 | 06:03 AM
  #32
Russ's Avatar
Weight saved on the tires/wheels is actually akin to 2.5x the actual static weight. Buy a newbie tire/wheel combo that is 7-lbs lighter per corner and you've essentially "dropped" 70-lbs from your car. Bear in mind wheel design (spoke location from hub, etc) has a bit to do with actual weight savings as well but this calculation is close enough. Disregard those who say the difference is 5-10x the amount (written on numerous other enthusiast boards from those who haven't done the research). I once participated in a thread (on another site) with contributions by a few (whose degrees qualified them to tackle the subject) and the general finding was a 2.5x factor. Anyone who has put lightweight 12-lb 16-inch wheels on their car can attest to the increase in performance that clearly isn't indicative of the "actual" weight decrease.
On another note, I usually run no more than a 1/2-tank of gas at all times because when I go on a trip and fill it up, I can definitely feel the difference in take-up with that extra weight (40-lbs or so). During the summer, when I'm tooling around looking to play, it's six bars or less. I drink a lot of 'Dew and it just gives me a reason to grab another 20 oz.
Old Dec 5, 2002 | 09:04 AM
  #33
Pixsurguy's Avatar
Query:
Spoon supposedly makes and sells aluminum suspension A arms. I'm sure that they are OUTRAGEOUSLY expensive.
I'm not sure of how much lighter they are, but regardless of the actual weight savings - looks like some of that weight would be "unsprung".
Any thoughts?
Old Dec 5, 2002 | 09:07 AM
  #34
Prolene's Avatar
I didn't think the trim panels could weigh that much. Something for me to consider....
Old Dec 5, 2002 | 12:00 PM
  #35
SteveUCI's Avatar
[QUOTE]Originally posted by Prolene
[B] I didn't think the trim panels could weigh that much.
Old Dec 5, 2002 | 12:10 PM
  #36
Prolene's Avatar
[QUOTE]Originally posted by SteveUCI
[B]
I thought you already gutted all that out!
Old Dec 5, 2002 | 01:05 PM
  #37
So what can go from the front of the car? Intake, AC (has anyone done this?), light battery, what else? My weight lost is biased toward the rear so far and I need to do something about it.
Old Dec 5, 2002 | 01:20 PM
  #38
Pixsurguy's Avatar
Yeah - same here. W/ the lighter wheels and brakes more is off the front than the rears, but the BIG diff. will be the 35 lbs. plus I lose off the rear from the Amuse Dual R1 Ti exhaust and the 30 lbs. plus I lose by removing the spare and tools.
REAR: (Total = 89 lbs. dropped)
Amuse Dual R1 Ti catback exhaust = 35 lbs. saved.
Pinnacle Brake system w/ "wave" rotors all around = 8 lbs less in the rear alone.
No spare or tools = 32 lbs.
Rega EVO wheels = 14 pounds
FRONT: (Total = about 39 lbs. dropped)
Spoon header = 6 - 8 lbs. saved.
Pinnacle Brake system w/ "wave" rotors all around = 18 lbs savedon the front.
Rega EVO wheels = 13.5 pounds
So - a drop in the front of 39 lbs. and 89 in the rear. Will that unbalance the car enough to cause more oversteer? I assume that the oversteer characteristic will increase, but I don't really know. I have seen conflicting views on that.
Old Dec 5, 2002 | 09:50 PM
  #39
j2k's Avatar
j2k
a weight increase to the rear will make the car head towards oversteer... and likewise an increase in front weight will increase understeer.
-jason keeney
Old Dec 6, 2002 | 12:47 AM
  #40
j2k's Avatar
j2k
[QUOTE]Originally posted by Russ
[B]Weight saved on the tires/wheels is actually akin to 2.5x the actual static weight.
