S2000 weight savings.
Old Dec 6, 2002 | 06:13 PM
  #51
ultimate lurker's Avatar
Jason is right.
I wrote a dissertation on this topic at VTEC.net a while back (and I'm not going to write it again), but suffice it to say that the torque required to accelerate the wheel tire combo is dependent on the MoI (moment of inertia) and the acceleration rate of the car. Although FCguy does make a good point.
SCC did an interesting test a few months back where they dyno tested heavy and light wheel combos on the same car in different gears. The heavier combos showed less hp (which is calculated back from wheel torque and gearing) across the board, but the difference was larger in the lower gears.
UL
Old Dec 6, 2002 | 06:17 PM
  #52
Mike Schuster's Avatar
Babyjoy, the plastic and puddy must be a water seal. Window switch velcroed on at the bottom.
jzr, your're right, sometimes two sessions and pump. It's a late '01: it just handles differently for some reason.
Old Dec 6, 2002 | 09:04 PM
  #53
Babyjoy's Avatar
While I have the utmost respect for your efforts to save the extra weight, can't say that I could get away with doing that to the future car with my fiancee. Her reply word for word would be..."I can't believe this... you spend $50,000 (C$) on a car and you rip the goddamn door trim off?"
Old Dec 6, 2002 | 09:28 PM
  #54
S2000typeR's Avatar
Gosh what's with people and weight savings?! Haha.. just IMO. I don't see the joy of gutting an interior unless you are only going to race it or to see who can save the most weight in their S2000. I dunno whatever..
Old Dec 6, 2002 | 10:10 PM
  #55
SEVNT4's Avatar
For anyone near Burbank, CA. There is a recycling center I remember going to a couple of years ago where you could drive your car onto a scale and weigh it for free. It's near San Fernando road but some of you guys might want to check out that option. Not sure who else has a ground scale that large.
Old Dec 6, 2002 | 10:17 PM
  #56
SEVNT4's Avatar
In fact, I think I found the place. Burbank Recycling Center
http://www.ci.burbank.ca.us/publicworks/Re...Recycle-Center/
Call ahead and see if they have that scale available.
Old Dec 7, 2002 | 02:54 AM
  #57
Russ's Avatar
[QUOTE]Originally posted by Mike Schuster
[B]Here is an updated list on my car:
Remove 8 gallons of gasoline -48
Remove exhaust (cut at y-split) -40
Remove right seat -35
Remove spare tire -25
Remove door panels -10
Remove tools -7
Remove washer fluid -5
Remove trunk trim -5
Remove audio unit, antenna, trim -4
Remove mats and visors -2
Remove cruise control -2
Remove speakers -4
Install JDM wheels and Michelin Cup tires -34
Install Ohlins coilovers ?
Old Dec 7, 2002 | 04:48 AM
  #58
Hondafan's Avatar
[QUOTE]Originally posted by SteveUCI
[B]
I thought you already gutted all that out!
Old Dec 7, 2002 | 05:25 AM
  #59
Prolene's Avatar
So what can go from the front of the car? Intake, AC (has anyone done this?), light battery, what else? My weight lost is biased toward the rear so far and I need to do something about it.
When I had the front bumper off, I considered taking out the steel front crossbeam, but decided against it. I think the beam might be contributing to chassis stiffness, and it has the receptor for the tow hook.
As for the door trim, I think I would miss the arm rest too much without the trim.
Old Dec 7, 2002 | 06:02 AM
  #60
FCGuy's Avatar
Originally posted by ultimate lurker
Jason is right.
Is the article still available at vtec.net? If so, can you supply a link?
